• English
  • 3DCoat Documentation
    • Introduction to 3DCoat
    • Getting started
    • Interface
    • Brush Components
    • Workspaces Rooms
    • Scripting & Core API
    • Questions/Answers
    • licensing
    • Training Tutorials
  • Blog Posts
  • English English
    • Українська Українська
    • Español Español
    • Deutsch Deutsch
    • Français Français
    • 日本語 日本語
    • Русский Русский
    • 한국어 한국어
    • Polski Polski
    • 中文 (中国) 中文 (中国)
    • Português Português
    • Italiano Italiano
    • Suomi Suomi
    • Svenska Svenska
    • 中文 (台灣) 中文 (台灣)
    • Dansk Dansk
    • Slovenčina Slovenčina
    • Türkçe Türkçe
    • Nederlands Nederlands
    • Magyar Magyar
    • ไทย ไทย
    • हिन्दी हिन्दी
    • Ελληνικά Ελληνικά
    • Tiếng Việt Tiếng Việt
    • Lietuviškai Lietuviškai
    • Eesti Eesti
    • Čeština Čeština
    • Română Română
    • Norsk Bokmål Norsk Bokmål
    • Getting started
    • Interface
    • Brush Components
    • Workspaces Rooms
    • Questions/Answers
    • licensing
  • Blog Posts
  • English English
    • Español Español
    • Deutsch Deutsch
    • Français Français
    • 日本語 日本語
    • Русский Русский
    • 한국어 한국어
    • Polski Polski
    • 中文 (中国) 中文 (中国)
    • Italiano Italiano
    • Suomi Suomi
    • Svenska Svenska
    • 中文 (台灣) 中文 (台灣)
    • Dansk Dansk
    • Türkçe Türkçe
    • Magyar Magyar
    • ไทย ไทย
    • हिन्दी हिन्दी
    • Ελληνικά Ελληνικά
    • Eesti Eesti
    • Čeština Čeština
    • Română Română
  • Getting started
    • Activating 3DCoat
    • Startup error
    • Folders Structure
    • Import and Export
      • Blender 4.1 applink
    • Quick Start Menu
    • Navigation Panel
    • Camera and Navigation
    • Viewport Navigation Gizmo
    • Space Bar Menu
    • Hotkeys
  • Interface
    • File
    • Edit
      • Preferences
    • View
    • Symmetry
    • Layers
    • Freeze
    • Curves
      • Curves editor
      • Fill with mesh layer
    • Windows
      • Tabbed and Popup Panels
      • Controls
    • Help
    • Room Customization
    • Modify or Create new Room
  • Brush Components
    • Brushes general use
    • Strokes
      • Curves Popup Menu
    • Brush Options panel
    • Strips Panel
    • Stencils Panel
      • Add new images or materials
      • Import Quixel Material
    • Presets for Brush alphas
  • Workspaces Rooms
    • Paint
      • Painting Modes
        • Per Pixel Painting
        • Lock Normals
      • Paint Menus
        • Textures Menu
          • Texture Baking Tools
        • Bake Paint menu
        • The Color Picker
      • Top Bar for the Painting
      • The Layers Panel
        • The Blending Panel
      • Left Tool Panel
      • Opacity & Transparency
      • Tweak tools
      • UV Top Bar
      • UV Left tool panel
      • UV Preview Panel
      • UV workflow example
      • Importing Into the UV Room
      • Exporting from the UV Room
      • Importing into Retopo Room
      • Retopo Mesh Menu
        • Virtual Mirror Mode
      • Strokes tool in Retopology
        • Select geometry
        • Overall Purpose & Function
        • Tweak Tools
        • UV Tools
      • Poly Groups
      • Sculpt Tree
      • Sculpt Brush options
      • Brush engine
      • Geometry menu
      • Right-Click Menu
      • Shader
      • Voxel mode
        • Pure Voxel Sculpting
        • Density and Resolution
        • Clay Engine
        • Voxel Tools
        • Surface tools on Voxels
        • Voxel Adjustment Tools
        • Volumetric Painting
        • Voxel Objects Tools
      • Surface mode
        • Surface tools
        • Surface custom tools
        • Surface adjust tools
        • Surface Painting
        • Surface Objects Tools
        • Multi Level Resolution
      • Sculpt curves
        • Spline Curves
      • Vector Displacement
      • Transform tools
        • Transform
      • Primitives
      • Live Booleans
      • Commands for Sculpt room
      • Import to Sculpt Room
      • Render Panel Functions
      • Turntable
      • Workflow
    • Simplest
        • Add Geometry
          • Selected
        • Tweak
        • UV modpanel
          • UV: Selected and Commands
        • Entire Mesh
      • Blockout by Poeboi
    • Kitbash
    • Nurbs
      • Sculpt shader Nodes Library
    • Scripting
  • Free 3DCoatPrint
Create kitbash
422 views 1
Greebles or Nurnies can be created in any 3D modeling application, usually with arbitrary extrusions.
This short tutorial demonstrates features of the version of Import tool
As far as we’ll work with Import tool we’ll need greebles (small details that helps models to look more ‘technical’).
It can be created in any application for 3D modeling, usually with a series of arbitrary extrusions. You can download greebles using link at the bottom of this tutorial.
To make your models look more interesting and unique you would probably want to create your own greebles.
Details with angled surface look better than with parallel to horizon:
For easier placing of details on a model create a contour for the detail (that’s an object with a name “_negative” which excludes from the model automatically and leaves a slot for the detail.)
Details with angled surfaces look better than surfaces that are all parallel.
For easier placement of details on a model, create a contour for the detail, an object with the name “_negative,” which subtracts automatically from the model and leaves a slot for the detail.
Turning on “Respect negative volume” in the Import Tool Panel is important to permit contour exclusion. Because the “negative volume” width is larger than the width of the detail, we get an interesting effect.
There is a joint between the body and the object. The detail looks as if it stands right on its place, and the body looks as if it has a special slot for the detail. Such joints look good with ambient occlusion.
Here is an example of how would it look without that effect. Looks not so interesting, and also there is a problem that was caused by different curvatures of the body and the detail – the detail looks tumbled down (it wouldn’t happen with negative volume).
Negative volume shouldn’t have the exact form of the body. You may change its form to get various effects.
It’s time to detail the object. For this tutorial I’ve made a small set of details, they all have “negative volume” (it can’t be seen on a screenshot).
We’ll also need a base to which we will attach all the details, of course if you don’t want to attach it to a default sphere :-). The Import tool will also help us here.
With such a concave surface you can make facets on objects.
Load the Greebles using the “Import” tool.
In transform regime cut any shape from a primitive.
You can also use frame for cutting but cuts made with Import tool looks more interesting than those made with a frame.
It’s time to detail the object. Load the greebles using Import tool. Use ‘on pen’ mode. Use ‘9’ and ‘0’ keys to rotate the brush.
That’s all
Primitives Library from Tinker
How to make ‘negative volume’
Steps:
1) On Modeling Room or your 3D app make a greeble.
Create another object in the same scene (that object will be ‘negative volume’)
As you can see the detail locates inside the capsule (’cause I’m gonna use capsule as ‘negative volume’):
Rename the second object (capsule in this case) as you like BUT (!!!) add “_negative” in the end. Like this:
Export in Wavefront (.obj) format.
Do everything as below is explained. And… enjoy the results:
If you export the model from Blender. Rename one object with _negative, but then you have to make sure you select “groups” in the export settings.
1 Yes  No
  • Space Bar Menu
Kitbash
Left tool panel Kitbash
