3D Coat Forums
haikalle
Blender Applink
I have updated the applink script and you can test it out.  Builds after (Build Oct 29 2018 02:15:29) will inlcude updated script.
Thanks for testing.  There was some issues with 3dc->blender workflow and I have send the fixes into blender2.8 code. Build after Nov 8 2018 01:30:04 will include these fixes.
Other thing I see from your screenshot is that you have exported .obj file. For now use only fbx file. I will add obj support at some point but in testing phase fbx support only.
But thanks again for support and please let me know if there is other issues coming on your way.
Edited by haikalle
Hello, I export metal material from 3d Coat to Blender, but in Blender it is displayed incorrectly as a dark surface, the picture looks very different metal in 3DCoat and as the same metal looks in Blender. You may be able to make a mapping match because it looks like a 3D Coat.
Thanks for reporting this. It seams that 3d-coat creates too dark diffuse color. I'm not quite sure is this bug of my script or 3d-coat. I ask about Andrew's help and let you know when this issue is fixed.
More then likely you just need to adjust how your script handles the map gamma (The Max applink materials all take gamma into account to avoid this issue).
shot1.thumb.jpg.bb534a98954afcf782727ec5c765a0a7.jpgshot2.thumb.jpg.397983f1bb851fcf5583cecddc2a2ca5.jpg
There is something else than gamma. If I export color texture using default Export presets everything is okey, but if I change it into Blender/Cycles preset 3d-coat creates bad color texture.  Other thing that I would like to fix is that when
I change preset. I'm not able select default preset anymore. I like simple setup of default preset but to get it back I have to delete my 3d-coat folder from documents.
Edited by haikalle
Did some more testing and it seams that right diffuse map is created only if you have default preset. If you select another preset then diffuse map is wrong. Hope Andrew could take look at this.
After exporting from 3 D Coat to Blender, the texture is no longer similar to metal, you need to rebuild the entire system of nodes and textures that are exported from 3 D Coat can only be used to customize the nodes in Blender to recreate the likeness of metal. If you take your advice, the texture is exported light but it still doesn't look like the visual point with the image in 3 D Coat. Perhaps the reason is different shaders, shaders in 3 D Coat and Blender are very different, also in the texture of the environment and mastering. Ideally, it would be if the export occurred with minimal changes in visual perception.
Make sure to send him a message (support@3dcoat.com) about it, as he doesn't frequent this forum that much and may not see it.
Hi! I did some testing and I used default preset for now because there is issues if you use any other preset. But my tests I have done, the likeness is quite good in my mind.
Hi, thanks for your plugin. Decided to use for testing a more complex model, and identified a few errors that appear periodically and I have the second day I can not understand why this is happening, many options have been tried. I'm sending you a file and screenshots.
Demo.blend
Thanks for you both it's very useful feedback.
CristophLE: I will take a look what's happening...
Alex_Velger: First thing is that remember to check "Treat material as separate textures" . I will take a look your blend file right now and see if there is something else odd.
27 minutes ago, haikalle said:
Благодаря вам и это очень полезно обратной связи.
CristophLE: Я буду смотреть, что происходит ...
Alex_Velger: Первое, что не забудьте проверить «Treat материал в виде отдельных текстур». Я буду смотреть файл смешивания прямо сейчас и посмотреть, если есть что-то еще странно.
Alex: Could you please and download the rar file and reaplace io_coat3d folder from blender2.8/2.80/scripts/addons. This version should fixes the problems you have.
ChristophLE: There seams to be some kind of problem when applink tríes to read texture list from texture.txt. Could help me that you could show what is inside of your texture.txt
(founded Documents/3d-coat/Exchange folder) So after you have done "Open in Original App" show what you textures.txt looks like.
io_coat3D.rar
Edited by haikalle
Script updated again to solve some stability issues. Download blender2.8 build later than Nov 12 2018 11:53:15 will include updated script.
Here is a quick video about one of the feature that applink supports. If you have saved your project in 3d-coat. Applink will bind that "3dcoat project filepath" into objects in blender. In large scenes you might have several objects that you
are working in 3d-coat. This feature helps to work between files quickly and easily. You can get access to 3dview 3d-coat applink menu by pressing 'Q' key.
And remember that this not only work when you work only one object. You can have sets of multply objects and this still works.
Edited by haikalle
I updated into blender2.8 just couple seconds ago so next build that is released will include this feature.
Edited by haikalle
