Andrew Shpagin Posted February 21, 2012 Author Report Share Posted February 21, 2012 Andrew, Excellent work on the new clone tool! New hope! Could you please put paint from a photo onto a model and show the cloned result and the original photopaint beside each other? The difference between images is the same as when you using transform (CTRL T) tool in Photoshop - single bilinear interpolation. 1 Link to comment Share on other sites More sharing options...
Advanced Member kay_Eva Posted February 21, 2012 Advanced Member Report Share Posted February 21, 2012 nice one andrew dude!! =p Link to comment Share on other sites More sharing options...
Advanced Member The Candy-floss Kid Posted February 21, 2012 Advanced Member Report Share Posted February 21, 2012 What about LWO? Any luck using that from 3DC? Yes Lightwave works fine. Liveclay getting so much better each update too - great fun last night playing with Liveclay. Link to comment Share on other sites More sharing options...
Member mercy Posted February 21, 2012 Member Report Share Posted February 21, 2012 The difference between images is the same as when you using transform (CTRL T) tool in Photoshop - single bilinear interpolation. Top excellent work, Andrew!! Very good results. You made it!!! This means clean industry advantage over: Mudbox 2012SP3: its photo paint is slow as hell on my GTX280, Mudbox clone distorts textures with weak projection code and does not recognize CUDA cards 1GB RAM, despite workaround environment variables set) Zbrush 4R2b: its "spotlight" 3D texture paint CANNOT paint onto lowpoly!! MARI:the best painting tool currently requires super-expensive PC with LOTS of RAM! Link to comment Share on other sites More sharing options...
Javis Posted February 21, 2012 Report Share Posted February 21, 2012 Yes Lightwave works fine. Liveclay getting so much better each update too - great fun last night playing with Liveclay. Thanks for checking! Link to comment Share on other sites More sharing options...
Advanced Member manticor Posted February 21, 2012 Advanced Member Report Share Posted February 21, 2012 Depends how big a 14 million polygon model is isn't it ? I find 14 million polys per part of model more than adequate for anything. I like you abn but sorry dude I'm still not agreeing with you on that one Link to comment Share on other sites More sharing options...
Advanced Member manticor Posted February 21, 2012 Advanced Member Report Share Posted February 21, 2012 I think it would be a good idea to add tesselation based on resolution of projected pixels so there is no pixelation without having to go to insane tri counts. Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 22, 2012 Author Report Share Posted February 22, 2012 Pixelation on image depends not only on density but more on painting technique. Even hge res without AA will show ledder on the edge. For sharp lines on t-short ledder will be invisible at all if edge between black and yellow will be a bit more antialiased - bigger width of contour edge will be used. Also if you need some features to look sharper you may increase density locally. This is obvious advantage over just etxture painting. Link to comment Share on other sites More sharing options...
Advanced Member manticor Posted February 22, 2012 Advanced Member Report Share Posted February 22, 2012 also vertex painting method needs a lot less data as only the triangles and colour are needed as opposed to the triangles ,the uvs and the texture map. Link to comment Share on other sites More sharing options...
Member MADjestic Posted February 22, 2012 Member Report Share Posted February 22, 2012 That may be true, but this supposed "crispness" compared to texture map painting is bogus. Even on a 14 million poly object, graphics are VERY pixelated The 'pixelated' effect that you mention is due to aliasing. Anti-aliasing techniques is a well studied subject. Rather than being upset and going on rant how this techniques is useless to you, I suggest to take a look on the bright side of things. Good job, Andrew! Definitely something useful, especially if the painted attribute values can be exported from 3DC together with the mesh. Link to comment Share on other sites More sharing options...
Advanced Member spacepainter Posted February 22, 2012 Advanced Member Report Share Posted February 22, 2012 Static objects that have been 3Dscanned with an accompanying texture that need to be " polished" and 3Dprinted , would benefit enormously from a direct workflow. I dream of: Load scan, sculpt, paint, sculpt, paint, print. The texture needs to be projected on the outside of the voxelhull, in such a manner that any additional piedestals are easy to add without losing the texturedata in the process. Then determine Thickness; 3,5 millimeter to suit the material, p.e. bioplastic or bronze. Link to comment Share on other sites More sharing options...
Advanced Member 3DCNC Posted February 22, 2012 Advanced Member Report Share Posted February 22, 2012 ." Also if you need some features to look sharper you may increase density locally. This is obvious advantage over just etxture painting. " Was thinking about this today. But I think we all appreciate that there are options to approach a project differently in 3D Coat whatever your pref. Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 22, 2012 Author Report Share Posted February 22, 2012 Mac & Linux builds updated to 3.7.05B Link to comment Share on other sites More sharing options...
Advanced Member manticor Posted February 22, 2012 Advanced Member Report Share Posted February 22, 2012 cool,what technique did you use for the panels dude? Link to comment Share on other sites More sharing options...
Advanced Member The Candy-floss Kid Posted February 22, 2012 Advanced Member Report Share Posted February 22, 2012 Where is the new vertex painting facility folks? Love to give it a spin but can't see it. Maybe I'm running the wrong version 3.0.4C Ah Ok just downloaded the latest version for Mac - so you can just start off in the paintroom in voxel surface mode - sweet :-) Ooooh it's lovely - thanks Andrew!! Link to comment Share on other sites More sharing options...
Advanced Member spacepainter Posted February 22, 2012 Advanced Member Report Share Posted February 22, 2012 Just update, that's antique. Link to comment Share on other sites More sharing options...
Member mercy Posted February 22, 2012 Member Report Share Posted February 22, 2012 I think I've been in 3D long enough to know what anti-aliasing is and that I can at least paint a straight line on a texture map without a hideous amount of pixelation..."aliasing" (better?).You call it a rant, I call it countering all this hype a good dose of reality. The attached image is using a 4k map. Could get the same on a 2k. Neither is as hard on the system as having to crank up the resolution on mesh (and then adding vertex color data on top of that). What advantage is that? You mean you can't increase LOCAL resolution on a UV map by scaling the islands/cluster where you want extra resolution in the same manner? It's been done for a few decades now. How is this some major breakthrough? Ptex will do essentially the same thing, but on the fly (increase local areas of density). I imported a midpoly model for PPP, set texture size to 4096. Drew 4 yellow lines where aliasing could be clearly seen at 100% res. Export Diffuse. Opened the TGA in photoshop. Resized the image with bicubic (best smooth for gradients) or bicubic smoother (best for enlargements) to 2048 x 2048. Aliasing disappeared at 100%. My target resolution was 2048x2048. Link to comment Share on other sites More sharing options...
Advanced Member The Candy-floss Kid Posted February 23, 2012 Advanced Member Report Share Posted February 23, 2012 Just ran into a bug in 3-7-05B for the mac. Attempts to switch into proxy mode creating hangs.Consistant and repeatable. Link to comment Share on other sites More sharing options...
Advanced Member simmsimaging Posted February 23, 2012 Advanced Member Report Share Posted February 23, 2012 While I again finding myself disagreeing with the adversarial tone, I do agree with Abnranger that vertex painting is of limited value for high res textures. 16 million poly's is about on par with a 4K map, but that's not that much really. Depends on the kind of work you do - that's entry level for many textures that I require. That said, vertex/poly paint is a *great* system for low to medium res texture work. PTEX or PP painting works well for higher res work (to a point - it is pretty laggy with high res and high res brushes for now). The only downside of having both is the split focus in development will likely mean that neither gets fully sorted out anywhere near as fast as if there were only the one. /b Link to comment Share on other sites More sharing options...
Advanced Member polyxo Posted February 23, 2012 Advanced Member Report Share Posted February 23, 2012 While I again finding myself disagreeing with the adversarial tone, I do agree with Abnranger that vertex painting is of limited value for high res textures. 16 million poly's is about on par with a 4K map, but that's not that much really. Depends on the kind of work you do - that's entry level for many textures that I require. No Technology suits all thinkable requirements at the same time. 4k even when entry Level for your highly specialized work is certainly not what everybody will need. Those who need a Tool to quickly create Design-Concepts can come along with far smaller Texture--Sizes. A 2k texture which isn't shabby for many purposes only requires 4Mio Polygons... Good also least that you still go the conventional Low Poly Route then - it's not being abolished after all. That said - I would not at all be surprised if Andrew came up with some sort of intelligent System to work on even far larger meshes as also possible in Zbrush with HD-Painting. Vertex-Paint was as he said a thing he had planned for long time already and I think it is good to deal with it when the Application is still relatively young as it may have greater consequences on how one has to plan the GUI. Especially when also parallel Painting and Deformation would get hooked up... The new System opens 3DCoat even more to non Digital Content Creation Industries. Medical users for instant who create Colour Facial Scans now could use 3DCoat to solidify the Model with Voxels and for fixing some Seams on their Scan-Results without having to go through a Retopo-Process/Baking Process. One thus far can spend 6Digits on such Scanners but one could not Postprocess them properly in any straightforward way.Going the Retopo-Way is no option for those Medical Users - it makes no sense for several good reasons. I think it's also utter Nonsense to say that having Vertex Painting and the conventional Route being developed at the same time will as clear consequence slow down the Development Process. Things are not always as linear and it's impudence to think that we Customers could forecast how things will further develop. Of course it's gotten an even more complex Project now. But when Vertex-Painting makes new Users maybe also from other Industries purchase the Software this could well pay off and additional Developers can get hired. 1 Link to comment Share on other sites More sharing options...
Advanced Member michalis Posted February 23, 2012 Advanced Member Report Share Posted February 23, 2012 OK, I managed to transfer vertex painting to blender (BTW obj isn't working, LWO does.) So what can I do next? I can't render it. Link to comment Share on other sites More sharing options...
Member define Posted February 23, 2012 Member Report Share Posted February 23, 2012 Hello andrew and thanks a lot for 3d-coat again. I just installed the last beta and all of a sudden I did't have any shaders left available in the voxel-room. already tried to deinstall everything and reinstall (newest beta) again - no shaders left. I then reinstalled the previous beta and voila the shaders were back. just to let you know. (64bit win7 on intel quadcore, 8 gb ram, nvidia 240 gt) best klaus Link to comment Share on other sites More sharing options...
Advanced Member 3DCNC Posted February 23, 2012 Advanced Member Report Share Posted February 23, 2012 a Tool to quickly create Design-Concepts for those who need it. It also helps new modellers get started without having to get bogged down with technical details. Scanning company's will also find it useful. Link to comment Share on other sites More sharing options...
Advanced Member 3DCNC Posted February 23, 2012 Advanced Member Report Share Posted February 23, 2012 OK, I managed to transfer vertex painting to blender (BTW obj isn't working, LWO does.) So what can I do next? I can't render it. found this on google. don't know if its useful. Blender - Vertex colors can be painted by switching to Vertex Paint Mode, however, it will not show up in the render unless you check "Vertex Color Paint in the Materials .. Link to comment Share on other sites More sharing options...
Advanced Member polyxo Posted February 23, 2012 Advanced Member Report Share Posted February 23, 2012 for those who need it. It also helps new modellers get started without having to get bogged down with technical details. Scanning company's will also find it useful. That's what I wrote too. A simple example of something previously impossible: Download the free program 123D Catch and 3DScan some item from you House just by using a simple Camera Load the Mesh as Voxels, Solidify and correct small or large defects Load Textures captured by the Camera as Vertex Colours Do Model Modification to your Hearts desire and blend them seamlessly with the Scandata use Fill Voids followed bý extract Skin save out as decimated .ply create colour 3D-print at service-supplier Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 23, 2012 Author Report Share Posted February 23, 2012 Hello andrew and thanks a lot for 3d-coat again. I just installed the last beta and all of a sudden I did't have any shaders left available in the voxel-room. already tried to deinstall everything and reinstall (newest beta) again - no shaders left. I then reinstalled the previous beta and voila the shaders were back. just to let you know. (64bit win7 on intel quadcore, 8 gb ram, nvidia 240 gt) best klaus Try to delete MyDocs\3D-CoatV3\Shaders\Custom Link to comment Share on other sites More sharing options...
Advanced Member 3DArtist Posted February 23, 2012 Advanced Member Report Share Posted February 23, 2012 OK, I managed to transfer vertex painting to blender (BTW obj isn't working, LWO does.) So what can I do next? I can't render it. I assume you are using cycles, create an Attribute node via Add -> Input and type the name of the vertex color map into the field on the node. Then just hook it up to the color on a shader and it should render. Link to comment Share on other sites More sharing options...
Advanced Member michalis Posted February 23, 2012 Advanced Member Report Share Posted February 23, 2012 @3DArtist Thank you ! It works. Link to comment Share on other sites More sharing options...
Advanced Member 3DArtist Posted February 23, 2012 Advanced Member Report Share Posted February 23, 2012 @3DArtist Thank you ! It works. Happy to help Hopefully soon the blender applink will support vertex colors. Link to comment Share on other sites More sharing options...
Advanced Member simmsimaging Posted February 23, 2012 Advanced Member Report Share Posted February 23, 2012 No Technology suits all thinkable requirements at the same time. 4k even when entry Level for your highly specialized work is certainly not what everybody will need. Those who need a Tool to quickly create Design-Concepts can come along with far smaller Texture--Sizes. A 2k texture which isn't shabby for many purposes only requires 4Mio Polygons... Good also least that you still go the conventional Low Poly Route then - it's not being abolished after all. That said - I would not at all be surprised if Andrew came up with some sort of intelligent System to work on even far larger meshes as also possible in Zbrush with HD-Painting. Vertex-Paint was as he said a thing he had planned for long time already and I think it is good to deal with it when the Application is still relatively young as it may have greater consequences on how one has to plan the GUI. Especially when also parallel Painting and Deformation would get hooked up... The new System opens 3DCoat even more to non Digital Content Creation Industries. Medical users for instant who create Colour Facial Scans now could use 3DCoat to solidify the Model with Voxels and for fixing some Seams on their Scan-Results without having to go through a Retopo-Process/Baking Process. One thus far can spend 6Digits on such Scanners but one could not Postprocess them properly in any straightforward way.Going the Retopo-Way is no option for those Medical Users - it makes no sense for several good reasons. I think it's also utter Nonsense to say that having Vertex Painting and the conventional Route being developed at the same time will as clear consequence slow down the Development Process. Things are not always as linear and it's impudence to think that we Customers could forecast how things will further develop. Of course it's gotten an even more complex Project now. But when Vertex-Painting makes new Users maybe also from other Industries purchase the Software this could well pay off and additional Developers can get hired. I think you basically just said the same thing in more words I agree that VP has a lot of use and potential, but agree with ABN that it's limited at this stage for hi-res work. It is neither impudence or nonsense to say that development is likely to be slower - it's just logical given: (a) limited resources and multiplied tasks, and ( the history of development thus far with 3DC and other software. Sure, sales could go up and so could development, but that is *less likely* to be the case. In any event, it's not a criticism of anyone - it is just how things are. Only time will tell though /b Link to comment Share on other sites More sharing options...
