The V4 Manual is slow as frozen molasses, whenever I try to use it...the one from the HELP menu. Anyone else notice this? I mean it takes 20-30sec just to go from one page to the next. If I use the manual from the mainpage, it's ok. It's just the one that is accessed from the app, itself.
AbnRanger,
I'm not experiencing the same thing. However, keep in mind that I often don't have the same problems as others, which may be attributed to my computer setup. The manual loads as a PDF on my end. Is this the case on yours?
I just saw this at Andrew's twitter page.
"16/32 tiff-exr allowed for masks and materials (precission kept)"
Thanks Andrew, your the best...
https://twitter.com/AndrewShpagin
That will make a couple of people quite happy. Hopefully some more of the long standing issues will be getting tackled soon.
This was not a request vs bug fixing post of mine. I owned 3DCoat since 2007 (V2) and we are now getting 16 / 32 bit tiff / exr support for materials and mask. I think us who wanted the support can to be happy... :drinks:
It was on my gigantor list that I sent to Andrew, compiled it from my needs and from others. I can easily say that I am happy to read that. I am looking forward to trying it out, should be very good. :)
Tweak UV vertices in Retopo Room is working well ?
here destroy the geometry moving ghosted vertices to anywhere
And delete one retopo layer group delete faces of another layer
Two questions.
Is there a way to give the preset brushes a own name?
There is a field that i could give the brush his own name, but after reopening 3d coat, i see the original name of that brush and not my custom name.
I love to save incremental, is there a way to change the SHIFT+CRTL+S to only CRTL+S and in the other way for normal saving?
Edited by Malo
  • Moderator
Hi,
try to first delete the hotkeys by hovering your mouse over the menu item and pressing BACKSPACE. Then press END and assign a new one :)
Thanks, works.
Now i need only help with the custom name of my brush presets.
right-click on the preset and choose "rename" or double-click on the current name. Same way you can change the layer name anywhere in the application
Yes, but if i close 3d coat and open it again, the custom name is gone and the preset brush use the original name again.
I use the LiveClay brush, i modify it, i save it, i rename it into Malo, everything looks OK, i close 3d coat, i open 3d coat, and i see LiveClay instead of Malo in my presets.
Something goes wrong on my side, but what?
That is strange, indeed. Try clicking the little triangle/drop list in the upper right hand of the panel and choose "save preset file." When you leave the app and come back, see if that doesn't store it permanently.
