Advanced Member Tser Posted May 30, 2013 Advanced Member Share Posted May 30, 2013 Which one is newer, the RC01 or the version from the download page (4.0.03)? T. Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/131/#findComment-94266 Share on other sites More sharing options...
Advanced Member Tser Posted May 30, 2013 Advanced Member Share Posted May 30, 2013 can i ask if tomorrows begin the... ? FEATURE REQUEST TIMEEEEEEEEEEEEEEEEEEEE !!!!!!! :rofl: :rofl: :rofl: I REALLY hope you are kidding, I just want stability and refinement of the features which are already there... Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/131/#findComment-94267 Share on other sites More sharing options...
Advanced Member michalis Posted May 30, 2013 Advanced Member Share Posted May 30, 2013 Feature request time? Here we are again... Mine will always be just one! Multi resolution sculpting, bake from multi resolution. Probably in the tweak room, mirroring all the sculpting tools. I know it is very hard for coding. Harder than it looks. Difficult to perform well. So, what stops Andrew? LOL Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/131/#findComment-94270 Share on other sites More sharing options...
PolyHertz Posted May 30, 2013 Share Posted May 30, 2013 I just want stability and refinement of the features which are already there... Features and refinement to tools can be considered one and the same depending on what you want. The little bugs in the UI itself though do make the program seem more unstable then it really is. Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/131/#findComment-94301 Share on other sites More sharing options...
Advanced Member Tser Posted May 30, 2013 Advanced Member Share Posted May 30, 2013 Refinement of existing features, not new features, meaning polishing and stabilizing existing features... Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/131/#findComment-94359 Share on other sites More sharing options...
PolyHertz Posted May 30, 2013 Share Posted May 30, 2013 Like I said, it depends on what you're referring to specifically. Like I would consider giving the Hide Tool in the Paint Room to ability to hide UV islands a feature, but you could also say that that's a refinement of its existing capabilities. If you'd like, feel free to give examples or link to them on Mantis. Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/131/#findComment-94363 Share on other sites More sharing options...
Advanced Member Tser Posted May 30, 2013 Advanced Member Share Posted May 30, 2013 Problem: 3DCoat V4.0.03 Linux (GL64) After Retopoing in the retopo room for a few hours, I clicked on the Commands>Clear by accident, but when I tried to undo (Ctrl+z or Edit>Undo) nothing happened, it would not undo, I then went to the preferences dialog and enabled auto save, as it was turned off, then saved the preferences, then all hell broke out with the UI with square blocks of colour randomly on the interface and total inability to do anything, I had to restart 3DCoat. Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/131/#findComment-94364 Share on other sites More sharing options...
Advanced Member Tser Posted May 31, 2013 Advanced Member Share Posted May 31, 2013 (edited) There is definitely something wrong with the undo, after working on a model for a while the undo doesn't work any more, and the smooth brush doesn't smooth!!! And when this happens I get a pop up "File write error!" Unable to write file; This is from the auto save.... Sergyi, I could do with your help on this one... Edited May 31, 2013 by Tser Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/131/#findComment-94394 Share on other sites More sharing options...
Andrew Shpagin Posted May 31, 2013 Author Share Posted May 31, 2013 There is definitely something wrong with the undo, after working on a model for a while the undo doesn't work any more, and the smooth brush doesn't smooth!!! And when this happens I get a pop up "File write error!" Unable to write file; This is from the auto save.... Sergyi, I could do with your help on this one... Ok, I shown the problem to Sergyi, he will deeply discover it. Stability is first priory. Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/131/#findComment-94395 Share on other sites More sharing options...
Advanced Member Tser Posted May 31, 2013 Advanced Member Share Posted May 31, 2013 Ok, I shown the problem to Sergyi, he will deeply discover it. Stability is first priory. Great, thanks Andrew. T. Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/131/#findComment-94397 Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted May 31, 2013 Reputable Contributor Share Posted May 31, 2013 Feature request time? Here we are again... Mine will always be just one! Multi resolution sculpting, bake from multi resolution. Probably in the tweak room, mirroring all the sculpting tools. I know it is very hard for coding. Harder than it looks. Difficult to perform well. So, what stops Andrew? LOL I wish at the very least, that the Tweak room gets a major update. Mirror all the basic Surface mode brushes, Transform tool, and possibly the Pose tool. This would be a more efficient environment for creating good morph targets and posing a low poly character. 1 Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/131/#findComment-94404 Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted May 31, 2013 Reputable Contributor Share Posted May 31, 2013 There is definitely something wrong with the undo, after working on a model for a while the undo doesn't work any more, and the smooth brush doesn't smooth!!! And when this happens I get a pop up "File write error!" Unable to write file; This is from the auto save.... Sergyi, I could do with your help on this one... I have had issues with UNDO plenty lately. Doesn't always occur, just under certain conditions. Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/131/#findComment-94405 Share on other sites More sharing options...
Advanced Member Tser Posted May 31, 2013 Advanced Member Share Posted May 31, 2013 I have had issues with UNDO plenty lately. Doesn't always occur, just under certain conditions. The thing that really tees me off is that when this happens it prevents you from saving your work, 3DCoat throws up a dialog stating that it could not read the contents of the folder - too many open files, so you have to restart and try to recover from a previous save. T. Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/131/#findComment-94410 Share on other sites More sharing options...
PolyHertz Posted May 31, 2013 Share Posted May 31, 2013 Assign Keys in Customize Navigation doesn't seem to be working anymore. Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/131/#findComment-94414 Share on other sites More sharing options...
Carlosan Posted May 31, 2013 Share Posted May 31, 2013 - BackGround images always show when jump to render room - Render room showed grid, and it wouldn't turn off. Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/131/#findComment-94421 Share on other sites More sharing options...
