Upgraded to v4.0.03 and Assign Keys seems to work now. Also noticed a new Modo navigation preset which I had just put in a feature request on mantis for like 2 days ago :)
Anyone else have an issue where sometime tablet pressure with make the cursor shake slightly?
Has anyone tried more than one variety of tablet or have a pref. (Possibly this is the wrong thread...) But I have a Bamboo ,which is great,but if I sculpt a fine line with minimal pen pressure,it seems every 4th/5th stroke starts off with a big blob which I have to undo, then the next stroke is fine.I don't know if this is 3DCoat (v4) or my tablet.I tried altering the pressure setting in prefs but that didnt help.
I get that too. Been meaning to ask Andrew about that. I try to adjust my brush settings to eliminate that (including spacing and depth profile), but I don't think that's practical to have to do with each brush. It should work smoothly by default.
I got the latest driver a few weeks ago.....I think.....maybe im confusing it with the GeForce driver i updated...anyway I do try and keep up to date. Maybe I will do a general search amongst other forums.....in between monstermaking ^_^
try cranking the depth curve (beside 3Dcoat depth slider) a tiny bit so it does not start at zero.
Please report if it worked or not.
mmm couldnt find anything called depth curve, so fiddled with everything in the brush options plus "falloff" and "flatten curves" on the top row ,no luck apart from now when I adjust the brush depth with my penbutton, it seems I have to move it more to make it move? Must have adjusted something I should have left....
Edited by stusutcliffe
I have found that using 3DCoat for any length of time (days), the OGL driver (Linux) gets hammered and you have to restart x to reload the driver.
Hello, Tser! Thanks for your observations! After quite a long research the reason of this problem has been found. But the reason has not been eliminated yet. You will see why later. It was possible to reproduce the OpenGL glitches with dots on the whole screen which affect any application under Linux (even menus and text). Sometimes the Linux hangs before those glitches appear and only hard reset helps. During those glitches CUDA version suffers from missing cubes under brush. As it turned out the memory management of OpenGL under Linux and under Windows differs. When 3D-Coat adds a texture the OpenGL driver under Linux sends it directly to the video memory. After a long time (after many added unique textures) the video memory of the graphics card ends up. OpenGL doesn’t report the application about the insufficient memory. OpenGL driver continues to successfully add textures, vertex buffers, shaders. They overwrite existing data in the video memory. There is a dialog which shows how many video memory left in the System>Preferences>More Preferences>NVIDIA X Server Settings>GPU 0 - (GeForce XXXX)>Used Dedicated Memory. Just before the described glitches appear the video memory is almost used. Just add a new texture to the 3D-Coat or create any new geometry and the problem raises. Especially fragile is CUDA version of 3D-Coat, because CUDA reserves big chunk of video memory.
to access the depth curve just hover the little pen icon that is just beside the depth slider in top of UI.
Got you..I opened up the graph,popped a new point in at the left hand side and dragged it down a bit to curve it.And I also tried just moving the first point at the far left up a square.Still not cured it, but I only got 4 blobbys out of 50 seperate strokes,which may be an improvement,but I diddnt do any counting before.Its good to learn about these mysterious little boxes though!
Hi there Sergyi, I don't have this OGL problem with any other application which uses OGL, I don't have any problem with the Linux X display and I am not using the Cuda version of 3DCoat, I run my system 24/7 and never restart it unless an update asks for a restart.
My new issue with the latest STABLE V4.0.03 of 3DCoat is that after using the program for a while, then taking a break for an hour or so, when returning to the program to do further work, I find that the program cannot save to the hard drive and on trying, gives a pop up dialog "Could not read the contents of xxxxx Too many open files" of course the xxxxx is the name of the folder that I am saving to, whats this all about, its as if 3DCoat cannot access my file system. All you can do after this happens is to restart 3DCoat and load a previously saved scene. I find it very frustrating working like this and will use ZBrush 4R5 (under wine in Linux) until you resolve this issue.
T.
Actually I use a Monoprice (UCLogic) tablet these days, switched from wacom about a half year ago. They're extremely cheap (about 1/7 the cost of a comparably sized Wacom) and have very good pressure sensativity. Their drivers do have some issues, but most of them there are ways around. Some more info: http://frenden.com/post/31659364200/the-little-monoprice-graphics-tablet-that-could
I'm running Linux 12.04 Ubuntu, using 3DCoat 4.0.03 non-cuda GL64 bit. So far I have not encountered the same problems as Tser's problem.
I have left the computer for several hours 3DC being left open and returned with no problems...
I always do manual saves not ever having used the auto-save feature.
This does not mean Tser does not have problems just reporting so far, I have not encountered them...
