Customization
This Chapter shows you how to totally customize 3DCoat.
Though the options are extensive, actual customization is a quick and simple process.
Hiding Elements from the Interface
From the “Edit” menu, choose “Customize UI”. You’ll notice that most menu items (of every category) and tools have a checkbox next to them, signifying that they can be made visible or not in the interface.
Some users only use 3DCoat for very specific tasks, in which case it would make sense for them to hide many interface item to reduce the overall clutter of unnecessary functions and options.
Just hide those elements of the interface that you find distracting and use keyboard shortcuts that give you access to the tools you need, only when you actually need them.
One of the most convenient “Pop-Up” tool panels is the “Tool/Color” panel. It contains all of the Painting Tools from the left tool panel, in addition to a handy color wheel.
Using and Customizing the UI: By Javis Jones.
Hide all
Use TAB if you like like to paint and texture with as much “blank” screen space as they can get and clutter of many interface elements. 3DCoat allows you to work in just this way.
Paint and texture, freely, and press the “Spacebar” when you need to change to a different Paint tool or color.
To access the Main Paint Functions panel, just press “~” on your keyboard to bring it to the front of your work space , right at your cursor location.
Tabbed Windows Popup Panels
Like many other applications, 3DCoat allows you to customize your workspace to suit your needs. You can hide or show windows, move tabbed popup windows around and even dock/undock them, or turn them into floating windows. If you don’t need or want to see a particular window, simply close it.
You can always bring it back into the interface through the Window menu at any time. Customizing your workspace makes 3DCoat work in the way that best suits your needs and workflow.
Use this menu to choose which function Panels you want displayed in the overall interface scheme.
These Panels can float freely or be docked into any portion of the interface, simply by dragging the Title Bar and dropping the Panel after you see the highlighted preview of its new position.
Any arrangement can be saved and reloaded.
Let’s take a look at how you can work with the interface. We’ll start off by moving tabbed popup windows around. We will discuss how to undock and dock tabbed windows and even how to create floating windows.
Tabbed windows are flexible in that you can change their widths and lengths and also their locations. This can be helpful if you’re using 3DCoat on a notebook computer and need to get as much screen real estate as possible to model or to do texture work.
Place your mouse along the edge or border of a tabbed window. When your cursor turns into a double-headed arrow, drag your mouse to resize the window.
To show a tab that you may have closed, or to explore tabs available for your use, go to the Window menu.
From here you can choose a tab to reveal in the interface. A great way to learn about the tools in 3DCoat is to open windows and to explore all of the functionality contained within it.
Moving a tabbed window to a new location is easy. You may want to move a tabbed window into another cluster of tabs. A good example may be to drag all windows that deal with colors or pens in a cluster so you can quickly find them.
Place your mouse over the tab and drag it to a new location.
Let go of the mouse when you see a blue outline. The position of the outline will determine which part of the window the tab will occupy. Let go of the mouse and the tabbed window will dock where the blue outline appeared.
Don’t worry if you placed it in the wrong location. You can always re-position tabbed windows until you’re satisfied with their locations.
You can create a floating window if you’d like by dragging the tab away from the tabbed window group it once occupied. Let go of the mouse and it will float as it’s own independent window.
You can dock a floating window back into any cluster of windows by dragging and dropping the window when you see the blue line.
Popup Window Menus
Many menus in 3DCoat have a small downward-pointing arrow in their upper right hand corners. When you click and hold your mouse cursor on them, they pop open to reveal menu-specific options.
Let’s say that you prefer larger icons when viewing Pens. Open the popup menu on the Pen tabbed window and choose Large to change the display size of the preview icons.
Adding Keyboard Shortcuts (Hotkeys)
When you select a tool or menu item from one of the Rooms, you can enable the option to see short or long “Hints”. These appear as you hover your mouse over the tool or function you are interested in, and you will see at the
end of the hint the following:
“(‘END’ - Define hotkey).
You can assign single and multi-button shortcuts to almost any 3DCoat function or tool directly in the user interface. Simply press the keyboard END key while moving the mouse over any element, followed by the keyboard shortcut of your choice.
If a hotkey is already assigned you will be asked if you wish to:
Reassign the key with the new tool/function.
Stack the tool/function with any previous tools/functions, allowing you to cycle between all of the tools with one hotkey.
Remove any tools/functions assigned to that key.
Defining Hotkeys: Showing how to set up custom hotkeys, using hotkey stacking or complete rebinding by Javis Jones.
Tutorials
Customize UI: This video demonstrates the usage of the “Customize UI” feature in 3DCoat; allowing the user to display only the tools they want or need.
Quick Tip_ Using Dual Monitors: This video is a brief demonstration of the ability to stretch 3DCoat's UI across 2 monitors, as a similar alternative to explicit dual-monitor support, which is not currently available.
Quick Tip: Assign Hotkeys to Workspace Tabs
Edit Text within the UI: Want to change the name of a tool or brush to better fit your preference, correct a typo that you may possibly find in a menu or tool description…or just reword something? The Edit Text Tags dialog will let you do it, instantly, and submit any changes to Pilgway, you think should be reflected in the default application.
Improved UI Customizations in Voxel Room: This video demonstrates some of the new improvements/changes to UI customization in the Voxel workspace in 3DCoat… including the ability to include presets into the tool Panel.
