3D-Coat 3.7 updates thread
1786 replies to this topic
#1401 Tony Nemo
Tony Nemo
    Expert
  • PipPipPipPipPip
  • 2,926 posts
  • Gender:Male
Posted 30 July 2012 - 02:27 AM
A twenty-four hour hiatus wouldn't be amiss. Oh, hell, go for forty-eight!
#1402 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • PipPipPipPipPipPip
  • 6,814 posts
  • Gender:Male
Posted 30 July 2012 - 07:38 AM
Updated to 3.7.16 (Win)
- To global space modified, To uniform space introduced - http://3d-coat.com/m...view.php?id=562
- Sketch tool problems fixed
- Delay when switching between tabs fixed
- Save/Open dialogs are splitting all possible extensions in several categories and are storing current folder in correspondence to category. In previous implementation in some cases stored folders was big mess with stored folders.
- Undo/Redo refined for differnt tools
- Undo/Redo implemented for Cache/Uncache
- Genius and other tablets will be supported. Wacom support rewritten too.
- 'G' key will ghost/unghost picked volume
- Specular contrast to Specular modulator in Layer options for convenience.
- UV improvement - you may select multiple UV islands, CTRL+C, select one island of similar topology and use CTRL V to put them on each other.
- A big list of mantis-reported issues fixed. This 2 weeks I concentrated on polishing 3DC.
www.3d-coat.com
Frequently asked questions
Brushing improvements thread
#1403 JimB
JimB
    Novice
  • PipPip
  • 365 posts
  • Gender:Male
Posted 30 July 2012 - 08:08 AM
I have downloaded 3.7.16 twice and the installer fails to run.
Amd Quad Core FX-4100 3.6MHz, GTX550 Ti 1GB GDDR5, 8GB DDR3
Wacom Intuos Pen & Touch Small (CTH-480), 3DConnexion SpaceNavigator ,Samsung 840 EVO ssd
Windows 8.1 Pro , Silo 2.3 ,3D-Coat V4 Pro,  Zbrush 4R7 ,TrueSpace 7
#1404 AbnRanger
AbnRanger
    Master
  • 6,252 posts
  • Gender:Male
Posted 30 July 2012 - 08:10 AM
Same here. I get an NSIS Error...saying integrity check has failed, etc...
#1405 Eric Cosky
Eric Cosky
    Neophyte
  • Pip
  • 88 posts
  • Gender:Male
Posted 30 July 2012 - 08:12 AM
Thanks for the update! I get the same error though, unfortunately.
#1406 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,814 posts
  • Gender:Male
Posted 30 July 2012 - 08:25 AM
ok, I will reupload, I had BSOD problems today...
www.3d-coat.com
#1407 stusutcliffe
stusutcliffe
    Novice
  • PipPip
  • 415 posts
Posted 30 July 2012 - 09:38 AM
Oh no, a glitch in "The Matrix" B) Mr Andrewson!
  • chingchong likes this
#1408 Taros
Taros
    Expert
  • Moderator
  • PipPipPipPipPip
  • 2,930 posts
  • Gender:Male
Posted 30 July 2012 - 11:21 AM
Is there no wacom pressure intensity settings anymore?
If the pressure is readed automatcally now, great.
@Andrew: Could you please explain, which changes you have made at the wacom drivers?
#1409 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,814 posts
  • Gender:Male
Posted 30 July 2012 - 02:02 PM
Now 2 api used - Windows Tablet PC for Genius and other but Wacom. Wacom still uses own sdk but in a bit different way. Generally it is made by Sergyi.
Btw, wrong build reuploaded.
www.3d-coat.com
#1410 BeatKitano
BeatKitano
    Khaaaaan!!
  • PipPipPipPipPip
  • 2,610 posts
  • Gender:Male
Posted 30 July 2012 - 03:53 PM
Still freezing with preset changes on hotkey. Uninstalling, I'll try it again when it's stable.
#1411 artman
artman
    Expert
  • PipPipPipPipPip
  • 2,242 posts
  • Gender:Male
Posted 30 July 2012 - 04:04 PM
Im not having freezes anymore using this build but I had to redo my presets...old presets generated big black explosions.
I redid them exactly like they were,same parameters...but now there is no freeze when i switch presets... even if I switch very fast.
Can you try redo them? if they work fine I can close this issue on Mantis.
Lest limbs be reddened and rent--I spring the trap that is set--As I loose the snare you may glimpse me there--For surely you shall forget
"The Wind In the Willows", Chapter 7 "The Piper at the Gates Of Dawn"
#1412 BeatKitano
BeatKitano
    Khaaaaan!!
  • PipPipPipPipPip
  • 2,610 posts
  • Gender:Male
Posted 30 July 2012 - 04:09 PM
I won't bother, Pressure=depth stroke thumbnail is not fixed (bug reported before even the first ui changes public release). This means when it's done I'll still have to redo those preset. I'm sick of doing the same thing over and over when this could be done once and for all.
I'll wait at this point 3dcoat is just a curious app for me, I don't really use it anymore anyway.
#1413 artman
artman
    Expert
  • PipPipPipPipPip
  • 2,242 posts
  • Gender:Male
Posted 30 July 2012 - 04:34 PM
What is that?
#1414 BeatKitano
BeatKitano
    Khaaaaan!!
  • PipPipPipPipPip
  • 2,610 posts
  • Gender:Male
Posted 30 July 2012 - 04:40 PM
What is that?
Save a preset with pressure= radius
Do the same with pressure=depth. Compare...
Xml change again if this is fixed, preset to redo...
#1415 artman
artman
    Expert
  • PipPipPipPipPip
  • 2,242 posts
  • Gender:Male
Posted 30 July 2012 - 04:45 PM
I don' understand,you mean E-panel pressure modes?
On my side they are stored properly in my presets and I have presets using all different modes.
#1416 BeatKitano
BeatKitano
    Khaaaaan!!
  • PipPipPipPipPip
  • 2,610 posts
  • Gender:Male
Posted 30 July 2012 - 04:50 PM
No.
Posted Image
Anyway it doesn't matter. Andrew said it was the way it is, first entry (pressure=depth) is not saved. End of story I guess... I wonder sometimes.
I'm betting this will go nevercenter's. Sooner or later. I'll be relieved when it happens.
#1417 artman
artman
    Expert
  • PipPipPipPipPip
  • 2,242 posts
  • Gender:Male
Posted 30 July 2012 - 05:02 PM
No.
Posted Image
Where do I set this? I don't even know what it is and what it does lol. Im intrigued.
#1418 artman
artman
    Expert
  • PipPipPipPipPip
  • 2,242 posts
  • Gender:Male
Posted 30 July 2012 - 05:12 PM
Where? I don't see that in my preset panel,I have it docked all the time...
Where do I set that red thing..lol.
#1419 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,814 posts
  • Gender:Male
Posted 30 July 2012 - 05:15 PM
Could be good to get your presets zipped to reproduce and fix it finally.
www.3d-coat.com
#1420 artman
artman
    Expert
  • PipPipPipPipPip
  • 2,242 posts
  • Gender:Male
Posted 30 July 2012 - 05:18 PM
No.
Posted Image
Ok...I understand.This is what I was talking about...E-panel pressure modes.
Well in the preset the icon is not displayed but the mode is stored properly...
if you switch brush presets you can see the pressure mode change as expected in the E-panel.
The issue is just about the "display' of the icon in the preset .....its really a minor issue.
I mean the pressure mode really get stored properly anyway...
edit:I see you've updated your image and added "thumbnail missing",that way I would have understood right away
Sorry if I misunderstood,I thought you had found some secret hidden 3DCoat pressure setting lol
