Please explain essence of the problem, I have not found it in this thread.
The problem I found is that when you select Paint Distortion, the single image is switched to tiling mode. You can not switch back to non-tile mode even for paint mode. You have to close the image and then sometimes your image will not load again in non-tiled mode even in paint mode till you close and reopen 3DCoat.
Painting distortion works but with the above problems. I did not fill out a bug report as you have a back log of bugs already. Reports get buried sometimes if there are too many at Mantis at one time plus I was waiting to see if Pixo filed one and then I could confirm his report.
Edit : Just tested again and it gets stuck in tiling mode till you close and reopen 3DCoat.
Show Voxels in Paint Room - always returns to 'on' whenever I reopen 3DC. Can someone else check that or see if I'm missing something.
Cheers.
another bug...
drag drop image from explorer to create new material,
switch between materials
drop another file to create new material
new material isn't the new map, but a clone of the last material
all newly dropped images will be clones
Updated to BETA6 (WIN only, Mac+Linux coming soon)
- big work performed over stabilizing and optimizing 3D-Coat. I hope LC tools will work much more predictably and faster. Many areas of 3D-Coat including paint, retopo, voxels was tested and a lot of bugs fixed. A lot of Mantis bugs fixed.
- options how ghosting will be treated (see top panel)
- Zooming in/out speed will depend on distance from the pivot point to perform better navigation
- Direct uploading to sketchfab.com done
Goodness me, I'm seeing a very big increase in speed whilst using large brushes. Had a quick play using backup copy of my Thing sculpt and LC brushes can be used at very large sizes.
Will do a side by side comparison... but I can already see it.
"Direct uploading to sketchfab.com implemented."
Where do I find this inside 3D Coat?
Thank you
Chris
Thanks for new ghosted volume options, much easier to work that way.
Continuing testing :)
Stroke quality is indeed improved (A LOT), surface is much less jagy than previously
I can get explosions if I try to push the smooth factor over 100% (toying around but if it's "normal" it should be locked to 100%)
-Symmetry is broken (on buildclay at least)
Yes, seems symmetry is broken in LC tools, thanks for reporting. I will re - upload.
