Advanced Member StereoMike Posted January 7, 2009 Advanced Member Share Posted January 7, 2009 What speaks against having an auto quadrangulation that has a nice poly flow? I'm sure this will be a killer feature when done right. I could imagine something like a drawing mode, where you roughly place areas that act as poles (e.g. knees, top head, knuckles) in one color, areas for cylindrical shapes in another color (depends on what info 3DC needs). So the automatic know where it has to place rings of polys (around the poles) etc. And maybe a line for general flow orientation (e.g. draw at the back of the character from the back of the head down the spine into two lines down the legs). mike Link to comment https://3dcoat.com/forum/index.php?/topic/1412-3d-coat-30-alpha/page/145/#findComment-13334 Share on other sites More sharing options...
Member Crusoe Posted January 7, 2009 Member Share Posted January 7, 2009 That's what those papers I posted talk about. In one, you can place control points to improve the edge flow. Andrew needed some help in finding libraries to compute EigenValues of sparse matrices. Link to comment https://3dcoat.com/forum/index.php?/topic/1412-3d-coat-30-alpha/page/145/#findComment-13336 Share on other sites More sharing options...
Advanced Member Jokermax Posted January 7, 2009 Advanced Member Share Posted January 7, 2009 thanks Andrew! One more important thing - can you move/copy Quadrangulation to Topology Tools please so it can be used on regular meshes(reference meshes/3d scans) directly. Agree 100%, I will support symmetry and plan even to auto - capture it.3DC tries to cover surface with planar patched, but some source polygones remain uncovered. Process is continued until all polygones will be covered. So 12 are not covered polygones, 406708 - covered. Yes, I am working on this. Please show screen. I will update in half of hour and prolong trial. I will fix it, but main aim of this update was quads. Link to comment https://3dcoat.com/forum/index.php?/topic/1412-3d-coat-30-alpha/page/145/#findComment-13340 Share on other sites More sharing options...
philnolan3d Posted January 7, 2009 Share Posted January 7, 2009 thanks Andrew!One more important thing - can you move/copy Quadrangulation to Topology Tools please so it can be used on regular meshes(reference meshes/3d scans) directly. A number of the voxel features would be nice to have for the full program, like rendering, but I think we'll have to wait for that if it ever does happen. Link to comment https://3dcoat.com/forum/index.php?/topic/1412-3d-coat-30-alpha/page/145/#findComment-13344 Share on other sites More sharing options...
Advanced Member kay_Eva Posted January 8, 2009 Advanced Member Share Posted January 8, 2009 What speaks against having an auto quadrangulation that has a nice poly flow? I'm sure this will be a killer feature when done right. I could imagine something like a drawing mode, where you roughly place areas that act as poles (e.g. knees, top head, knuckles) in one color, areas for cylindrical shapes in another color (depends on what info 3DC needs). So the automatic know where it has to place rings of polys (around the poles) etc. And maybe a line for general flow orientation (e.g. draw at the back of the character from the back of the head down the spine into two lines down the legs).mike That's what those papers I posted talk about. In one, you can place control points to improve the edge flow. Andrew needed some help in finding libraries to compute EigenValues of sparse matrices. yeah Andrew, control points!!! If you can find away to procedurally modify the quadrangulation via control points, kind of like tweaking and manipulating a rig for animation, then all you'd have to do is intelligently get those control points to interract. And of course you only insert control points where needed, already the feature works really well! Link to comment https://3dcoat.com/forum/index.php?/topic/1412-3d-coat-30-alpha/page/145/#findComment-13351 Share on other sites More sharing options...
Andrew Shpagin Posted January 8, 2009 Author Share Posted January 8, 2009 1- when I toggle off perpspective and switch to orthogonal view3dCoat completely freeze for aprox 1minute at ANY change of settings. examples of changes :inc render on/off,multicore on/off,change camera view,select a brush ect... it happens only if I toggle perspective off,and only in DX version(Gl is fine) Ok, I will check. Are you sure it is "uniq 48 feature"? and I can't use the Gl version because I still got "ghost" selection when I use transform(not transpose)see the green and pink there,this never goes away,even if I save and load back I still not able to reproduce it... Please send me any example of "damaged" 3B file to fix it immediately (support@3d-coat.com). 2- (most dramatic as it is my main working tool))Substractive action with E panel does nothing( I'm aware I must hold ctrl while doing it) It only works on the default sphere. But it doesn't work if I use it on .3b files from previous alpha. Also...there is still no substractive action from "curves" implemented only closed spline(very hard to do a sheild with this), polylines (impossible to do rounded cuts) and Handraw (very hard to do rounded cuts because of hand shaking) it should be easy to do since it is (in my head) a mix of polylines and handrawn curves and both are already there. It was last hours change, I will improve it very soon. Link to comment https://3dcoat.com/forum/index.php?/topic/1412-3d-coat-30-alpha/page/145/#findComment-13356 Share on other sites More sharing options...
Advanced Member Skaven252 Posted January 8, 2009 Advanced Member Share Posted January 8, 2009 One more important thing - can you move/copy Quadrangulation to Topology Tools please so it can be used on regular meshes(reference meshes/3d scans) directly. I would second that for the Render panel. It would be handy to be able to render clear images of your normal textured 3D models as well. Currently you have to either take a screenshot or import the model and its textures to an external application to render (unless I've missed something?). Link to comment https://3dcoat.com/forum/index.php?/topic/1412-3d-coat-30-alpha/page/145/#findComment-13364 Share on other sites More sharing options...
Advanced Member erklaerbar Posted January 8, 2009 Advanced Member Share Posted January 8, 2009 wow, this is really going into the right direction. Love the quadrangulation feature, keep it up. best Link to comment https://3dcoat.com/forum/index.php?/topic/1412-3d-coat-30-alpha/page/145/#findComment-13372 Share on other sites More sharing options...
Contributor artman Posted January 8, 2009 Contributor Share Posted January 8, 2009 Erklaerbar!...Wow! The god of shaders have setted foot here. please make some 3dcoat shaders!! Link to comment https://3dcoat.com/forum/index.php?/topic/1412-3d-coat-30-alpha/page/145/#findComment-13376 Share on other sites More sharing options...
Contributor artman Posted January 8, 2009 Contributor Share Posted January 8, 2009 Ok, I will check. Are you sure it is "uniq 48 feature"? I've been toggling perspective on/off a lot in all alphas since 42 because it is normal action when working and I didn't have any problem so far. to be more precise it's alpha48 Dx64cuda ,I coudn't test 32bit because I have cuda64x but I'll try with non-cuda before going to bed. I still not able to reproduce it... Please send me any example of "damaged" 3B file to fix it immediately (support@3d-coat.com). File sent.Just the default sphere scaled on one axis. Scaling is the key action to generate the problem.(move and rotate are alright) Maybe Someone with QuadroFx1700 should also test this. anyone?....GL 64 cuda...not DX thanx Link to comment https://3dcoat.com/forum/index.php?/topic/1412-3d-coat-30-alpha/page/145/#findComment-13377 Share on other sites More sharing options...
Andrew Shpagin Posted January 8, 2009 Author Share Posted January 8, 2009 I've been toggling perspective on/off a lot in all alphas since 42because it is normal action when working and I didn't have any problem so far. to be more precise it's alpha48 Dx64cuda ,I coudn't test 32bit because I have cuda64x but I'll try with non-cuda before going to bed. File sent.Just the default sphere scaled on one axis. Scaling is the key action to generate the problem.(move and rotate are alright) Maybe Someone with QuadroFx1700 should also test this. anyone?....GL 64 cuda...not DX thanx I looked file, it seems to be shader-related problem Try default, bronze and lamblight - they work fine, other have problems. Link to comment https://3dcoat.com/forum/index.php?/topic/1412-3d-coat-30-alpha/page/145/#findComment-13380 Share on other sites More sharing options...
Contributor artman Posted January 8, 2009 Contributor Share Posted January 8, 2009 I looked file, it seems to be shader-related problemTry default, bronze and lamblight - they work fine, other have problems. thank you so much...now I can try testing alpha48 more deeply .. but I liked clay and greyclay shaders so much,they are 3DC's best sculpting shaders EDIT:haha...there is a workaround: the trick is to use the lamblight shader only when using transform, transform doesn't require a good sculpting shader,the rest of the time you can still work with the clay shader (the best cavity balance shader) thanx again Link to comment https://3dcoat.com/forum/index.php?/topic/1412-3d-coat-30-alpha/page/145/#findComment-13381 Share on other sites More sharing options...
philnolan3d Posted January 8, 2009 Share Posted January 8, 2009 I noticed something that I didn't see before and I'm not sure what it does. I VS sculpted something, then retopo'd it, then while I was marking the edges for the UV I saw that a colored ball would appear if I clicked on a polygon, not an edge. What does that ball do? Is it new or did I just miss it before? Link to comment https://3dcoat.com/forum/index.php?/topic/1412-3d-coat-30-alpha/page/145/#findComment-13384 Share on other sites More sharing options...
Contributor artman Posted January 8, 2009 Contributor Share Posted January 8, 2009 Andrew, About the freezing thing when toggling perspectiive off I found out you need to cut model with E panel first for ortograhic bug to come out. (on my machine at least) Link to comment https://3dcoat.com/forum/index.php?/topic/1412-3d-coat-30-alpha/page/145/#findComment-13386 Share on other sites More sharing options...
Advanced Member kay_Eva Posted January 8, 2009 Advanced Member Share Posted January 8, 2009 Andrew, About the freezing thing when toggling perspectiive offI found out you need to cut model with E panel first for ortograhic bug to come out. (on my machine at least) Andrew, after a few ctrl+Z's the undo feature stops working for me Link to comment https://3dcoat.com/forum/index.php?/topic/1412-3d-coat-30-alpha/page/145/#findComment-13387 Share on other sites More sharing options...
