3D Coat Forums
@Carlosan
Radeon ProRender may have some licensing issues?
Step 2 says "sign a Radeon ProRender Commercial Software Licensing Agreement"
Have not looked into the details, but ProRender seems nice and cross platform.
Now for Cycles and Lux, I integrated them into unity over 3 years ago.
https://bit.ly/2UIZSt3
both are fairly easy to integrate, send mesh and shader/texture data...render to memory buffer, display
converting shaders is not that hard with PBR, they are "physically based" which is kinda universal.
any path tracer will be noisy (cycles), but just as example...32 samples (a few seconds) with my unity plugin using optix
2IoQ9BC
Edited by bocs
I do high resolution sculpt, vertex paint it, then render.  Keyshot doesn't seem to support vertex color.  Right now I am stuck with 3d coat internal render, unless I retopo/uv so I can render it in blender's eevee. :(
To be honest, I think you would find it to be a better alternative to use Instant Meshes to create a fast and good looking mesh to bake to. In the Retopo Room, you can choose Auto-Seams > Unwrap and then bake. That would probably deliver the best results without having to spend a bunch of time in Retopo or UV's.
This should help explain the Baking process. The finished result will land in the Paint Workspace, ready to export with any baked texture maps.
Thanks, I will take a look and do a test on it.
Edited by animk
I have never tried SL version because there were too many things I need to learn, and afraid it may often clash etc,,  (the discription of Andrew ^^;)
But I recently see 3d coat training video about SL version,, and am interested much,,
 then is there demerit to use beta SL compare with non SL beta ? (I  use beta version most of case,  because I do not need to make product. and hope to use new future, like new spline tools etc,,) ?  eg it is more often shut down ,etc?
All the SL versions are Beta, until there is a major release. Andrew may deem a build "Stable" usually after he's spent some time bug fixing, so that there are stable builds available every few months or so. The latest builds seem pretty stable when using Sculpt Layers.
Thanks now I download SL version first time, then see how Sculpt layer work ^^ if it already work  as same as current non SL beta, 4.8.37 about other tools . there seems no meaning keep both beta version.. :D
I thought Keyshot did, I guess I am mistaken.( I thought you could send straight from zbrush to Keyshot with polypaint.)
I use Marmoset Toolbag  , it has vertex paint support, its not that expensive and they have 30 % off every now and again.
When I import to Marmoset, the specular is defaulted to 1 which makes the vertex colours 100 percent reflective so it looks like its not working, so you have to bring the slider back down to 0 for the colours to appear.
Maybe Keyshot does a similar thing.
Thanks, I googled vertex color keyshot, it looks like keyshot supports vertex color from zbrush only, I could be wrong.
Finally found a solution.  I duplicate and decimate a higher res painted mesh, then add resolution (by using add detail smooth method) back to decimated mesh on where detail paintings are needed.
Using reproject tool (SL version) to re-project mesh detail and vertex color back to decimated mesh.
It's way easier than retopo/UV and keep most of the details on a much smaller size mesh.
Edited by animk
So are you still rendering in 3dcoat? Im not quite sure im following this ...are you back to where you started from but just with a smaller mesh, if so I am curious to know how big your original mesh was. I think Ive managed about 20-25 million and still managed to render in 3dCoat. ( Marmoset will just about manage this also.)
( a side note... I've exported a vertex painted mesh via FBX to Zbrush and it opened perfectly!  I dont see why Keyshot would be just ZB centric.......Disclaimer-- Not an expert! :wacko:)
Glad you found a solution!
Is it already reproted?
When use curve tools and select the curve, then move with GIzmo, even though I input value for x,y,z it not reflect current curve postion.
1. activate curve tool
2. select curve then use "transform" from curve menu.
3 with check on,  move only gizmo , then To center mass to locate pivot on the curve center.
4  check off move only gizmo, then transform curve . but if I input value, gizmo only move the postion,,
I am not rendering in 3d coat.  I export the decimated meshes about 4 million tris  to blender,  it's a little slow but workable.
From keyshot manual "The Vertex Color texture is used only with geometry imported from other 3D applications that supports vertex color texture maps. Do not use this texture if you are not importing from a compatible 3D application as it will have no affect."
It looks like keyshot supports object with vertex color sent from other applications (through plugins), I guess it doesn't support vertex color from imported mesh. So I was wrong about keyshot on supporting zbrush only.
Thanks for the follow up!
Edited by animk
Good info to know, I shall have to try it and compare eevee to marmoset.
Edit. On second thoughts , just had a look...way out of my depth with that, I will stick with Toolbag its really basic.
Edited by stusutcliffe
added
I said earlier about decimating meshes to 40 million tris, I edited to 4 million, sadly blender's performance is just not that strong.
I think you'll get better results if you try the Auto-Retopo (Instant Meshes option is really sturdy and reliable) > Auto UV > Bake route. It should only take a couple of minutes, tops.
I tried this method, small details are still missing.  Baking with normal or displacement doesn't give good result.   It works for hard surface and big shapes.
When you say "doesn't give good results," do you mean the displacement in the (Paint Room) viewport doesn't show properly? If that is the case,  you can go to the bottom of the VIEW menu and click ADJUST TESSELLATION and increase the subpatch levels. That will help a lot. Otherwise, I'd be curious to see a screen recording showing the poor results...to help determine if we either need to make some adjustments or if Andrew needs to fix something.
I managed to get better result by checking sharp creases in IM, I will continue to play with it.  If the polygons flow along the surface the result gets better.
Unfortunately, this is not reproduced. Try installing the latest version.
Hi Oleg
Thanks to test, but it is not what I reported. because you use "space" key, to set transform value, with Gizmo.
 Then I confirm it work. (before I reported about it too) about recent versions.
But about this problem,  I use Gizmo Postion values in Tool options, to locate Curve as I need.
 If I use same property value, for voxel object transform tool, it can locate mesh with the postion value. when "Move only gizmo not active" as I expected.
If Curve tool need to use with space key, I think it only work to decide delta value from current postion. is not it?
eg I need to set current curve postion as gloval (0, 10, 10). but at current only Gizmo move with the postion values. not curve follow it.
https://www.dropbox.com/s/1iht79z85b6p5n3/coattest2_20190416_055658.wmv?dl=0
above link can show wmv what I asked. so if you could check really apreciate.:)
Edited by tokikake
 - Fixed problems related to tiling and filling layer with material.
 - Fixed a lot of errors related to curve modifiers and instancing volumes, loading/saving scenes with instances and modifiers.
 - Fixed "To uniform + Undo" problem.
 - Fixed problem of mesh exploding during extrude faces in retopo room.
  • Like 3
Yes, now I see a problem. Thank! But I do not promise that it will be fixed soon. The curves are still in development.
4 hours ago, Andrew Shpagin said:
4.8.38
Thanks Andrew. There was a reported bug regarding new HDRI panoramas being converted to greyscale.
