• English
  • 3DCoat Documentation
    • Questions/Answers
  • Library
    • Training Tutorials
    • Multilanguage switcher
    • Questions/Answers
  • Library
    • Different Forms of โ€œResolutionโ€
    • ย Activity Bar
      • Windows Panels
      • Painting Modes
      • Paint Tool Panel
      • Retopo tool panel
        • Voxel Adjust
      • Mod Tool panel
        • UV category
      • Shader Nodes Library
ID map
1637 views 0
3DCoat can import and utilize ID maps, but it does not have a simple, one-click function to automatically bake them from a high-poly sculpt like some other software.
Using ID Maps in 3DCoat
  • Importing: You can import an externally created ID map (from a program like Blender, Maya, or Substance Painter) by going to the Textures menu and selecting Import Layers Colors. This imports the map as a new layer in your layer stack, which you can then use for masking and selections.
  • Manual Creation (Workaround): A common workaround within 3DCoat involves manually assigning different, bright, flat colors to different UV islands or material sections in the texture editor. This can then be exported as a PSD file and saved as a PNG for external use.
  • Alternative Workflow: 3DCoat offers a powerful Fill tool that can limit the fill area by polygon angle, which often reduces the need for a dedicated ID map for hard-surface painting, allowing users to apply smart materials to specific areas with a single click.
While the software requires a more manual approach or an external program to generate the initial map, it does support incorporating ID maps into its texturing workflow for masking and isolating areas.
DAZ Genesis models into 3DCoat
Paint Menus
