Twitter discussion: What Andrew is currently doing.
Great news, We will be able paint the surface mode voxels/polygons in the paint room directly and eventually voxels in the paint room too. I was hoping that was the way it was going to work.
If this direct voxel paint is as good as it sounds with no need to ever do UVs etc then some of the current painting/texture options would definitely be obsolete. Though if that is the case it might mean the GUI could be optimized a lot i guess.
UVs will definitely NOT become obsolete with that feature. Image you have to export your painted textures to another application - you will definitely need to bake your textures onto a layed-out uv map. The main use of direct paint on voxels will be to postpone the retopo and uv process to a stage past the initial design, so you can get faster feedback from your client/director. It will also be great for illustration and rapid prototyping.
Yes, the only time you would not need UVs (in almost all cases) is if you're using Ptex, which is not used by much right now.
Quotes from @AndrewShpagin
ok, seems finished voxel surface painting up to beta stage. All layer operations supported, but some previews still missing.
Probably will do update in 2-3 days.
  • 2 weeks later...
All boolean operations [even between volumes] will preserve vertex color.
Andrew's mind is on steroids, creative programing steroids...
Nice! I really like that, I was hoping he would be able to implement this, and I'm glad he did. That should make voxels much more useful in this new workflow.
I'm curious to see just how far you can push it, I doubt it would be perfect if you change the voxel model too much. It is very cool though.
I'll just be happy that it keeps the paint/colors at all, whereas now it removes all color information if you switch from surface to vox mode, and back again.
  • 1 month later...
I just wanted to mention I am working on a feature length documentary intended for IMAX and in stereoscopic. Some of the shots we are doing involved digitally recreating skin at the microscopic level. We have scanned referance from electron microscopes, Art Director wanted 40+ million poly resolutions to get incredibly detailed inter cellular structures.
The work would be impossible to do without Voxels in 3d-Coat. I was working with 100 million points often enough, with instances and layers so I found perfomance acceptable at these resolutions with an intelligent use of caching and downsampling. Also, I quickly discovered that 24gb of RAM is not enough to export a 100million triangle mesh so there was no point in trying to work in higher resolutions.
Because of the nature of interlocking cellular structures i was creating, doing any retopology work would be impossible so creating UVs was not an option. Exporting as quads is an awesome feature that proved really useful for simpler assets, but still required cleanup of non-manifold geometry.
Just want to say that painting on voxels would be the perfect logical step forward, but how is the color data going to translate into other applications?
And that's related how?
Because it is perfect. A perfect follow up to what Beat said when he said, "Perfect". Perfect. :)
Interesting to hear 2byts that youre pushing the limits of painting
In this way.
Great that emissive paint, is it for glow in the dark effects?
  • 1 month later...
Yeah I've had some ui issues that have bugged me ever since we got the new ui. Hopefully this will cover at least one or two of those.
  • 3 months later...
I think this is the first time I've ever seen Andrew tweet something that wasn't a software update.
I think that Apple's patent about pinch to zoom and using it against Samsung is just theft from humankind's knowlendge base.
It just stops technical progress. I am frustrated and angry that such things may even happen.
Patenting obvious things and using them against competitors is just moral crime.
This really pushes me to wish to make 3DC at least partially opensource. Things are really not on the place in this world.
I would most certainly have to agree with what he has said. Patents, particularly coming from huge US company's, are getting out of hand. There is a small medical research company here in Australia that are developing a cure's / treatments for some cancers, yet their efforts looked like they will be stymied by patents on human genes by companies that discovered the genes. Here's a link on whats happening;
http://www.abc.net.au/news/2012-05-14/mp-urges-labor-to-back-gene-patenting-overhaul/4010612
Surely, at some point, common sense will prevail and laws will uphold what is the right thing to do, not what is most profitable. I really hope so, though I'm not getting my hopes up just yet.
Andrew tweet said this phrase ? :blink:
Like a Pilgway Foundation ?
interesting B)
http://www.abc.net.a...verhaul/4010612
I've always found it bizarre that genetic patterns can be patented. Plants and animals of all sorts patented. I cannot believe it's true, to be frank. It's a hugely busted system when you can patent something that occurs naturally. Now if someone came up with something completely unique, maybe, and only then (still a big maybe) do I feel like it could be patented.
Anyway, it's a huge discussion. I hope in Oz things change there, as it should globally.
