• English
  • 3DCoat Documentation
    • Questions/Answers
  • Library
    • Training Tutorials
    • Multilanguage switcher
    • Questions/Answers
  • Library
      • Windows Panels
      • Painting Modes
      • Paint Tool Panel
      • Retopo tool panel
        • Voxel Adjust
      • Mod Tool panel
        • UV category
      • Shader Nodes Library
Noise
873 views 0
Overview: A 2D noise node generates procedural, repeating volumetric patterns across 2 spatial dimensions (X, Y). Unlike 3D textures, 2D noise maps dependently of UV unwrapping, showing visible seams, stretching, or tiling repetitions on complex 3D meshes.
Cell2D
Description: Cell 2D noise nodes (often called cellular, Voronoi, or Worley noise) procedurally divide 2D space into distinct organic, geometric, or cellular regions based on the distance to randomly distributed feature points.
Inputs and Settings:
  • UV Coord: Input UV coordinates.
  • Frequency: Unified range.
  • Sharpness: General hardness
  • Scale:
  • DeformX:
  • DeformY:
  • OffsetX:
  • OffsetY:
  • Jitter: Cell deformation
  • CellProfile:
Outputs:
  • Color: RGB color output (Color (RGBA))
  • Normal: Normal vector in tangent space (Non Color (RGBA))
  • NonColor: Procedural pattern in grayscale (Non Color)
  • Opacity: Opacity mask for transparency (Number (Float))
CellNoise
Description: procedural texture generator in computer graphics that divides space into distinct regional compartments, or cells, based on the distance to randomly scattered feature points.
  • Scale:
  • Distort Intensity:
  • Distort Scale:
  • CellProfile:
  • Bright:
  • Contrast:
Outputs:
Clouds
Description: procedural generation tools for 2D clouds
  • Scale:
  • Distort Scale:
  • CellProfile:
  • Bright:
  • Contrast:
Outputs:
FBM
Description: (Fractal Brownian Motion) noise node combines multiple layers (octaves) of basic procedural noise- such as Perlin or Simplex noise- at increasing frequencies and decreasing amplitudes to generate realistic, organic textures like clouds, terrain, and fire.
  • Scale:
  • Distort Scale:
  • CellProfile:
  • Bright:
  • Contrast:
  • Lacunarity:
  • Rugosity:
Outputs:
FlowNoise
Description: generate Perlin-style procedural patterns with an added flow parameter that rotates noise vectors.
  • Luminance:
  • Midtones:
  • Shadows:
  • Scale:
  • Size X:
  • Size Y:
  • Distort Scale:
  • Contrast:
  • Flow:
Outputs:
FourierNoise
Description: generate deterministic or random frequency spectra using Fourier series expansions.
  • Luminance:
  • Midtones:
  • Shadows:
  • Scale:
  • Size X:
  • Size Y:
  • Distort Scale:
  • Contrast:
Outputs:
Lava
Description: procedural magma shaders by combining procedural generators (like Perlin or Voronoi noise) with color ramps, math multipliers, and emission parameters to simulate glowing cracks, cooled rock boundaries, and fluid displacement.
  • Scale:
  • Distort Scale:
  • Bright:
  • Contrast:
  • Line Color:
  • BG Color:
Outputs:
NoiseWave2D
Description: ports math-based wave and noise algorithms from ShaderToy to generate animated or static 2D wave patterns.
  • Scale:
  • Worminess: Cell deformation
  • Distort Scale:
  • Bright:
  • Contrast:
Outputs:
PaperDirt
Description: procedural paper and dirt textures involves combining basic noise generators with color and bump controls.
  • Luminance:
  • Midtones:
  • Shadows:
  • Scale:
  • Size X:
  • Size Y:
  • Distort Scale:
  • Contrast:
Outputs:
PatinaGrunge
Description: combining basic procedural noise generators (like Perlin or Voronoi/Cells) with math and color nodes to simulate dirt, wear, oxidation, and aging.
  • Luminance:
  • Midtones:
  • Shadows:
  • Scale:
  • Size X:
  • Size Y:
  • Distort Scale:
  • Contrast:
Outputs:
Perlin2D
Description: procedural generation tools used in software like Blender, Unity, and Substance Designer to create smooth, organic random patterns.
  • Scale:
  • DeformX:
  • DeformY:
  • OffsetX:
  • OffsetY:
  • Distort Scale:
  • Bright:
  • Contrast:
Outputs:
PerlinNoise
Description: continuous gradient values rather than harsh static, making them ideal for simulating natural phenomena like terrain, clouds, and fluid movement.
  • Scale:
  • Distort Scale:
  • CellProfile:
  • Bright:
  • Contrast:
Outputs:
Plasma
Description: generate organic, cloud-like, or fractal patterns used for motion graphics, procedural backgrounds, and texture displacement.
  • Scale:
  • Distort Scale:
  • Bright:
  • Contrast:
Outputs:
SimplexLab
Description: generate smooth, multi-dimensional pseudo-random gradients mimicking natural patterns.
  • Luminance:
  • Midtones:
  • Shadows:
  • Scale:
  • Size X:
  • Size Y:
  • Distort Scale:
  • Contrast:
Outputs:
SimplexNoise
Description: procedural generation building blocks.
  • Scale:
  • Distort Scale:
  • Bright:
  • Contrast:
Outputs:
SimplexPerlin2D
Description: procedural generation that outputs variations mimicking natural patterns like clouds, terrain, or marble.
  • Frequency:
  • Sharpness:
  • Scale:
  • Deform X:
  • Deform Y:
  • Offset X:
  • Offset Y:
  • Distort Scale:
  • Bright:
  • Contrast:
Outputs:
SimplexWorms
Description: generate smooth, multi-dimensional pseudorandom values without the noticeable directional grid artifacts of classic Perlin noise. When paired with “worms” techniques (such as Perlin/Simplex worms or cave-carvers), they carve interconnected, organic tunnel systems or side-scrolling destructible terrain.
  • Luminance:
  • Midtones:
  • Shadows:
  • Scale:
  • Size X:
  • Size Y:
  • Distort Scale:
  • Contrast:
Outputs:
Value2D
Description: generates a pseudo-random, smoothly interpolated pattern of scalar values across a 2D coordinate space.
  • Scale:
  • Offset X:
  • Offset Y:
  • Distort Scale:
  • Bright:
  • Contrast:
Outputs:
Voronoi2D
Description: generates procedural cell-like patterns by calculating pixel distances from a jittered grid of random points.
  • Frag Coord: Input UV coordinates.
  • Noise:
  • Blur:
Outputs:
  • Distance to point:
  • Color ID:
  • Relative Center:
  • Sharp Center:
  • Distance to border:
  • Cell Local UV:
Voronoise
Description: procedural generation that creates cell-like, organic patterns by calculating the distance between pixels and a grid of random points.
  • Pixel Coord: Input UV coordinates.
  • Luminance:
  • Midtones:
  • Shadows:
  • Scale:
  • Size X:
  • Size Y:
  • Distort Scale:
  • Contrast:
  • Jitter:
  • Softness:
Outputs:
WhiteNoise
Description: a procedural generation to output completely random values or colors based on an input coordinate or seed.
  • Scale:
  • Distort Scale:
  • Bright:
  • Contrast:
Outputs:
Worms
Description: procedural cave/river generation.
  • Luminance:
  • Midtones:
  • Shadows:
  • Scale:
  • Scale X:
  • Scale Y:
  • Scale Z:
  • Distort Scale:
  • Contrast:
Outputs:
Math
Noise3D
