Reputable Contributor AbnRanger Posted May 21, 2014 Reputable Contributor Share Posted May 21, 2014 I noticed also that when working on multiple objects (and multiple UVs) in retopo, ctrl-z always changes the current UV to the default UV. Once burned, twice warned: if you are not alert to this undesirable change, you will find your work is on the wrong UV. Yep....and that gets on my last nerve. That is DEFINITELY a bug, cause it didn't start happening until the last several builds. Link to comment Share on other sites More sharing options...
Advanced Member Boonta Posted May 22, 2014 Advanced Member Share Posted May 22, 2014 (edited) I was getting some crazy lag in 4.0 and 4.1 recently when i would change between tools (Within the same brush set ( i have noticed this also causes lag but that's another issue...) but yeh i would get crazy lag switching from a brush to a eyedropper etc. the only way i managed to resolve it was to rebuild the scene (re import the obj and then import in layer colors psd...) i couldnt think of what triggered the lag as it was working great all day. The only thing i can think that i did differently was at one point i did a CTRL+P and sent my file to photoshop briefly then back again. not sure if this corrupted anything in the file? No ICC profile was saved at that point .. however i was initially using a psd that had a icc profile embedded? Just thinking out aloud as to reasons for causing it........ p.s. bug: psd import still ignores a set opacity % setting in the file for layers. i.e. multiply layer @ 50% opacity will import at 100% Edited May 22, 2014 by Boonta Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted May 22, 2014 Reputable Contributor Share Posted May 22, 2014 I was getting some crazy lag in 4.0 and 4.1 recently when i would change between tools (Within the same brush set ( i have noticed this also causes lag but that's another issue...) but yeh i would get crazy lag switching from a brush to a eyedropper etc. the only way i managed to resolve it was to rebuild the scene (re import the obj and then import in layer colors psd...) i couldnt think of what triggered the lag as it was working great all day. The only thing i can think that i did differently was at one point i did a CTRL+P and sent my file to photoshop briefly then back again. not sure if this corrupted anything in the file? No ICC profile was saved at that point .. however i was initially using a psd that had a icc profile embedded? Just thinking out aloud as to reasons for causing it........ p.s. bug: psd import still ignores a set opacity % setting in the file for layers. i.e. multiply layer @ 50% opacity will import at 100% Try downloading the latest build (4.1.07B), as Andrew did some work over the past several builds to make 3D Coat more compatible with PS. If that doesn't work, send an e-mail to support@3d-coat.com He's currently working in the Paint Room, so if there are indeed issues in the app...not just an isolated issue on your end (ie., a buggered up OPTIONS.XML file), then it would be a good time to address it Link to comment Share on other sites More sharing options...
Advanced Member alvordr Posted May 22, 2014 Advanced Member Share Posted May 22, 2014 Mac too - progress = spinning beach ball of death. Mac - standard convention requires, cmd key should emulate right click. I thought that was Cntl key. Link to comment Share on other sites More sharing options...
Advanced Member The Candy-floss Kid Posted May 23, 2014 Advanced Member Share Posted May 23, 2014 I thought that was Cntl key. The cmd key is going spare :-) Link to comment Share on other sites More sharing options...
PolyHertz Posted May 23, 2014 Share Posted May 23, 2014 I've been wondering for a while now, is 3DC mostly a weekend project for Andrew? Seems like updates are almost always on Saturday/Sunday. Link to comment Share on other sites More sharing options...
Carlosan Posted May 23, 2014 Share Posted May 23, 2014 I've been wondering for a while now, is 3DC mostly a weekend project for Andrew? Seems like updates are almost always on Saturday/Sunday. 3DC build and server uploads are mostly a weekend task. Link to comment Share on other sites More sharing options...
Contributor artman Posted May 23, 2014 Contributor Share Posted May 23, 2014 I've been wondering for a while now, is 3DC mostly a weekend project for Andrew? a weekend project?? I really don't understand the meaning of this question. Link to comment Share on other sites More sharing options...
PolyHertz Posted May 23, 2014 Share Posted May 23, 2014 a weekend project?? I really don't understand the meaning of this question. Ah, I meant is the majority of work is done over the weekend? I'm not actually sure if Andrew works on 3DC fulltime or has another job asside from it. Not trying to be rude, just seems like that's when Andrew mostly posts and when updates are released. Link to comment Share on other sites More sharing options...
Contributor artman Posted May 23, 2014 Contributor Share Posted May 23, 2014 Ah, I meant is the majority of work is done over the weekend? I'm not actually sure if Andrew works on 3DC fulltime or has another job asside from it. Not trying to be rude, just seems like that's when Andrew mostly posts and when updates are released. How does the release day of the updates has anything to do with when the work is done?? I dont understand the logic behind your question. If betas were mostly released on tuesdays would it imply Andrew only work on tuesdays?? 2 Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted May 24, 2014 Reputable Contributor Share Posted May 24, 2014 Yeah. You don't pump out this many new features and bugfixes working on weekends. Just not humanly possible. Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted May 24, 2014 Reputable Contributor Share Posted May 24, 2014 ...after all, this isn't Messiah Studio or Silo (drumroll.....splash!) . 1 Link to comment Share on other sites More sharing options...
Contributor BeatKitano Posted May 24, 2014 Contributor Share Posted May 24, 2014 ...after all, this isn't Messiah Studio or Silo (drumroll.....splash!) . Wrong, leap year's day projects. 1 Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted May 24, 2014 Author Share Posted May 24, 2014 Updated to 4.1.08 - Chiesel/flattern got improvement - much more predictble trajectory and better quality. Normals sampling got better algorithm - normals are sampled along trajectory, not in just end spot. - Noise tool introduced in surface mode with realtime preview and infinite details. Pay special attention to anisotropic mode. It is good for natural stones. In Normal mode it is good planet generator. This tool is only initial iteration for future noise tool, node editor expected there. - Vertical lathe curve - ui in primitives polished a bit (tooltips, icons). - fixed very important problem that was happening sometimes (mostly depending on computer and OS, most frequent on Win 8.1) that was causing strokes screwing. 26 May - 5 June I will be in vacation - we will get rest on villa in Cyprus just with my wife. Romantic time I will be there one day more, so if something awful will be found - I still will be able to fix. 5 Link to comment Share on other sites More sharing options...
philnolan3d Posted May 24, 2014 Share Posted May 24, 2014 Can't wait to try out these features! Hope you have a great time with the wife! Link to comment Share on other sites More sharing options...
PolyHertz Posted May 24, 2014 Share Posted May 24, 2014 (edited) Also has this small but welcome tweak: http://3d-coat.com/mantis/view.php?id=1170 ---- Speaking of moving layers, the current visual indicator for where the layer is to be dropped has always seemed sort of inexact to me. It highlights the layer that the one being moved to bill be next to, but it doesn't specify if it'll be dropped above or below it. A line between the layers showing exactly where it'll be dropped instead of a highlight seems to me like it would make far more sense: Edited May 24, 2014 by PolyHertz 4 Link to comment Share on other sites More sharing options...
Advanced Member Grimm Posted May 24, 2014 Advanced Member Share Posted May 24, 2014 Any chance on a Linux build of this version before you go on holiday? Jason Link to comment Share on other sites More sharing options...
New Member J-A-K Posted May 24, 2014 New Member Share Posted May 24, 2014 Thanks for the upgrade Mate, Love the new Noise Maker. Have a great Holliday. Link to comment Share on other sites More sharing options...
Member fingers Posted May 24, 2014 Member Share Posted May 24, 2014 Thank you for the update, Andrew !!! Have a good time in Cyprus with your wife too Link to comment Share on other sites More sharing options...
Carlosan Posted May 25, 2014 Share Posted May 25, 2014 Bug ? Preferences Show import thumbnails in start page Select Surface mode Head Noise Generator Tool Realtime Preview (<-- typo warning*) Switching ON OFF ON Crash --------------------------------------------------------------------- Noise destroy symmetry if isnt in VIEW MODE, any setting to avoid it ? //edit a save/load option will be cool This is freaking time saver... TY VERY MUCH !! Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted May 25, 2014 Author Share Posted May 25, 2014 Any chance on a Linux build of this version before you go on holiday? Jason There is big chance. I asked Sergyi to make build. Even if I will leave, he will post it there. Link to comment Share on other sites More sharing options...
Advanced Member Grimm Posted May 25, 2014 Advanced Member Share Posted May 25, 2014 Excellent! Thank you very much, and thanks to Sergyi as well. Jason Link to comment Share on other sites More sharing options...
New Member Rayman29 Posted May 25, 2014 New Member Share Posted May 25, 2014 Downloads seem not to be working. Are there some location restrictions? Link to comment Share on other sites More sharing options...
Carlosan Posted May 25, 2014 Share Posted May 25, 2014 Rayman: will you please try again and post the result ? There was uploading a new version 8A -------- note about version 8A - head + noise bug = solved, ty - Noise destroy symmetry = solved - Realtime Preview typo = solved - Vertical lathe curve Sorry but cant find the change... i was waiting this: //edit i forgot to say... noise respect freeze tool = cool Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted May 25, 2014 Author Share Posted May 25, 2014 4.1.08A uploaded to solve symmetry and crash problem. 2 Link to comment Share on other sites More sharing options...
Carlosan Posted May 25, 2014 Share Posted May 25, 2014 noise tool is an humanoid factory ! lol Displacement = 20 Size = 210 Sharpness = 0 Seed = use any random number to see changes Noise = Anisotropic 2 Link to comment Share on other sites More sharing options...
Contributor tree321 Posted May 25, 2014 Contributor Share Posted May 25, 2014 I was expecting this too... Link to comment Share on other sites More sharing options...
PolyHertz Posted May 26, 2014 Share Posted May 26, 2014 Made a mantis report for the issue I listed in my above post: http://3d-coat.com/mantis/view.php?id=1507 Link to comment Share on other sites More sharing options...
Advanced Member wilson66 Posted May 26, 2014 Advanced Member Share Posted May 26, 2014 Noise tool is very nice, I like it. But yeah, I noticed this too. The lathe tool is not oriented vertically, but still horizontally. Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted May 26, 2014 Author Share Posted May 26, 2014 Updated to 4.1.08B: - lathe vertical - chiesel tweaked - solved problem with symmetry on CTRL action, alpha rotated along stroke and modulated so that shape is maximally accurate, normal orthogonal to trajectory, it allows to avoid too quick and irregular diving into surface. This is last update before my vacation. I will fly tomorrow morning. 2 Link to comment Share on other sites More sharing options...
