Advanced Member animk Posted April 13, 2019 Advanced Member Report Share Posted April 13, 2019 13 hours ago, AbnRanger said: When you say "doesn't give good results," do you mean the displacement in the (Paint Room) viewport doesn't show properly? If that is the case, you can go to the bottom of the VIEW menu and click ADJUST TESSELLATION and increase the subpatch levels. That will help a lot. Otherwise, I'd be curious to see a screen recording showing the poor results...to help determine if we either need to make some adjustments or if Andrew needs to fix something. I managed to get better result by checking sharp creases in IM, I will continue to play with it. If the polygons flow along the surface the result gets better. Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted April 15, 2019 Report Share Posted April 15, 2019 On 4/12/2019 at 5:30 PM, tokikake said: Is it already reproted? When use curve tools and select the curve, then move with GIzmo, even though I input value for x,y,z it not reflect current curve postion. Unfortunately, this is not reproduced. Try installing the latest version. Link to comment Share on other sites More sharing options...
Advanced Member tokikake Posted April 15, 2019 Advanced Member Report Share Posted April 15, 2019 (edited) Hi Oleg Thanks to test, but it is not what I reported. because you use "space" key, to set transform value, with Gizmo. Then I confirm it work. (before I reported about it too) about recent versions. But about this problem, I use Gizmo Postion values in Tool options, to locate Curve as I need. If I use same property value, for voxel object transform tool, it can locate mesh with the postion value. when "Move only gizmo not active" as I expected. If Curve tool need to use with space key, I think it only work to decide delta value from current postion. is not it? eg I need to set current curve postion as gloval (0, 10, 10). but at current only Gizmo move with the postion values. not curve follow it. https://www.dropbox.com/s/1iht79z85b6p5n3/coattest2_20190416_055658.wmv?dl=0 above link can show wmv what I asked. so if you could check really apreciate. Edited April 15, 2019 by tokikake Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted April 16, 2019 Author Report Share Posted April 16, 2019 4.8.38 - Fixed problems related to tiling and filling layer with material. - Fixed a lot of errors related to curve modifiers and instancing volumes, loading/saving scenes with instances and modifiers. - Fixed "To uniform + Undo" problem. - Fixed problem of mesh exploding during extrude faces in retopo room. 3 Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted April 16, 2019 Report Share Posted April 16, 2019 10 hours ago, tokikake said: If I use same property value, for voxel object transform tool, it can locate mesh with the postion value. when "Move only gizmo not active" as I expected. If Curve tool need to use with space key, I think it only work to decide delta value from current postion. is not it? eg I need to set current curve postion as gloval (0, 10, 10). but at current only Gizmo move with the postion values. not curve follow it. https://www.dropbox.com/s/1iht79z85b6p5n3/coattest2_20190416_055658.wmv?dl=0 above link can show wmv what I asked. so if you could check really apreciate. Yes, now I see a problem. Thank! But I do not promise that it will be fixed soon. The curves are still in development. Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted April 16, 2019 Reputable Contributor Report Share Posted April 16, 2019 4 hours ago, Andrew Shpagin said: 4.8.38 - Fixed problems related to tiling and filling layer with material. - Fixed a lot of errors related to curve modifiers and instancing volumes, loading/saving scenes with instances and modifiers. - Fixed "To uniform + Undo" problem. - Fixed problem of mesh exploding during extrude faces in retopo room. Thanks Andrew. There was a reported bug regarding new HDRI panoramas being converted to greyscale. Link to comment Share on other sites More sharing options...
Advanced Member tokikake Posted April 16, 2019 Advanced Member Report Share Posted April 16, 2019 Thanks 3D coat developer teams I know all about curves tools are still in development process. No hurry . Just expect it will be offered as stable powerful tool. Link to comment Share on other sites More sharing options...
Taros Posted April 16, 2019 Report Share Posted April 16, 2019 On 4/5/2019 at 11:52 AM, animk said: EEvee is great, too. It's real time or almost real time. I always render my sculpt in eevee, but need to decimate my sculpt before importing to blender, because it takes blender forever to import a large file. "Professional" animation solutions have the same problem and need a poly reduction, too. So no matter... Link to comment Share on other sites More sharing options...
Taros Posted April 16, 2019 Report Share Posted April 16, 2019 On 4/10/2019 at 7:15 AM, bocs said: @Carlosan Radeon ProRender may have some licensing issues? Step 2 says "sign a Radeon™ ProRender Commercial Software Licensing Agreement" Have not looked into the details, but ProRender seems nice and cross platform. Now for Cycles and Lux, I integrated them into unity over 3 years ago. https://bit.ly/2UIZSt3 both are fairly easy to integrate, send mesh and shader/texture data...render to memory buffer, display converting shaders is not that hard with PBR, they are "physically based" which is kinda universal. any path tracer will be noisy (cycles), but just as example...32 samples (a few seconds) with my unity plugin using optix Just a note: The NVIDIA AI Denoiser is already supported by "D-NOISE" a free AddOn for blender and works great. But let us move this topic better to a seperate thread... 2 Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted April 16, 2019 Report Share Posted April 16, 2019 7 hours ago, tokikake said: Thanks 3D coat developer teams I know all about curves tools are still in development process. No hurry . Just expect it will be offered as stable powerful tool. For now, use the top panel to move, if that helps. Link to comment Share on other sites More sharing options...
Advanced Member druh0o Posted April 16, 2019 Advanced Member Report Share Posted April 16, 2019 On 4/2/2019 at 5:42 PM, Andrew Shpagin said: Context sensitive RMB menu in retopo room, it is especially helpful in "Select" tool for low-poly modeling. That's great. But is it possible that this menu does not appear when i'm still holding the Alt key while navigating (Alt+RMB). Sometimes this can be annoying and can lead to errors when you miss it and click some function randomly. 1 Link to comment Share on other sites More sharing options...
Advanced Member druh0o Posted April 16, 2019 Advanced Member Report Share Posted April 16, 2019 11 hours ago, Andrew Shpagin said: 4.8.38 - Fixed problems related to tiling and filling layer with material. - Fixed a lot of errors related to curve modifiers and instancing volumes, loading/saving scenes with instances and modifiers. - Fixed "To uniform + Undo" problem. - Fixed problem of mesh exploding during extrude faces in retopo room. Oh, and now we have the bridge tool. Awesome! Link to comment Share on other sites More sharing options...
Member dniitall Posted April 17, 2019 Member Report Share Posted April 17, 2019 4.8.38 major problems switching between surface and voxels. takes forever or crash (crash most of the time). no such problems in 4.8.35 Link to comment Share on other sites More sharing options...
Advanced Member tokikake Posted April 17, 2019 Advanced Member Report Share Posted April 17, 2019 (edited) @Oleg_Shapo 11 hours ago, Oleg_Shapo said: For now, use the top panel to move, if that helps. Thanks to teach me the option. I do not know, if it have been there already , I hope if future version can move these menu to another place which can be more compact and easy find.p(eg I think they can be moved as Curve layer top menu, or add one more section "Curve options" ,which controll each curve or segments postion, scale etc) Because These "Point postions" (when select segments) and "Center" x, y, z , sclale x, y, z often ,not visible without I keep stretch 3d View right side. ========= And yes finally we can use bridge tool !!! This new beta seems really good up-date for me.. (I can confirm, curve tool Swept N gener becom more stalbe too ) Edited April 17, 2019 by tokikake Link to comment Share on other sites More sharing options...
Advanced Member tokikake Posted April 18, 2019 Advanced Member Report Share Posted April 18, 2019 I do not know when it started, but about some exr , it often lost color infomation when I use them as enviroment map. I have used some exr (blender cloud etc), then it work (eg can open in gimp, or blender , ds), but when I import them as enviroment map, they do not work for 3d coat. it lost color infomation then only generate black and white enviroments.. Is there any limitation about 3d coat env exr image ? it seems not change with (normalize or not normalize) Link to comment Share on other sites More sharing options...
Carlosan Posted April 18, 2019 Report Share Posted April 18, 2019 Grey scale Panorama i switched off ? Link to comment Share on other sites More sharing options...
Advanced Member tokikake Posted April 18, 2019 Advanced Member Report Share Posted April 18, 2019 (edited) 1 hour ago, Carlosan said: Grey scale Panorama i switched off ? I often forget these improtant option setting, but about this case, I keep the Grey scale Pnorama swithced as OFF (so not use it) As you can see, About imported EXRs, which I use "Panorama list" to add image,, some map show as gray scale. but some keep colors. To confirm I try to import another HDRI (16K) image as new neviroment, but it show as gray only.. Edited April 18, 2019 by tokikake Link to comment Share on other sites More sharing options...
Carlosan Posted April 18, 2019 Report Share Posted April 18, 2019 Could you share it to take a look ? Link to comment Share on other sites More sharing options...
Advanced Member tokikake Posted April 18, 2019 Advanced Member Report Share Posted April 18, 2019 Unfortunately I can not share them.(these are not free downloadable ones) I tried more low res version (eg 8k, 4k) about these maps, but no luck. On the other hand, I can import other HDRI EXR without problems. (So I have not found this problem) Link to comment Share on other sites More sharing options...
Carlosan Posted April 18, 2019 Report Share Posted April 18, 2019 Reported. Importing this panorama FORMAT=32-bit_rle_rgbe, same issue found. Link to comment Share on other sites More sharing options...
Advanced Member tokikake Posted April 19, 2019 Advanced Member Report Share Posted April 19, 2019 Thanks Carlosan to report. I do not know what make difference to change as grey only about these HDRI, but I tried to re-save as Open-exr with Gimp from your reply. file size becom large,, from 340M to 430M when convert garage.hdr to garage.exr (16k) But when i try to import the new saved garage.exr , 3d coat deny it to open as enviroment map. just , say "incorrect extends, look like png" . Link to comment Share on other sites More sharing options...
Carlosan Posted April 19, 2019 Report Share Posted April 19, 2019 Your hdr file size is 430Mb ? Link to comment Share on other sites More sharing options...
Advanced Member tokikake Posted April 19, 2019 Advanced Member Report Share Posted April 19, 2019 I believe so ,it is most high-quarity version which I downloaded before (blender cloud, though I have no inention to PR blender cloud etc,,) then Gimp or xnconrvert viewer etc, can load it with color. (hdr version). daz studio too. So I do not know what cuase problem for 3d coat. I tried with directX version too, but it seems same. Then it is just test , (I hoped to see how it look, with use same HDRI for final render, to adjust metal mat) so it not cause me serious problem, But I hope , Andrew test with many format. (at leas about format, which t 3d coat support) Link to comment Share on other sites More sharing options...
Reputable Contributor Silas Merlin Posted April 26, 2019 Reputable Contributor Report Share Posted April 26, 2019 It has really become a challenge to weld vertices using right click with the Add/Split tool, because of the popup menu. Doesn't anyone else have this issue ? Also, not really related to the beta builds, but I think it would make sense to automatically force-select the brush tool when you click Retopo menu > Bake with normal map (because if you have another tool selected when you start, you can't brush to tweak the inner/outer shell) Link to comment Share on other sites More sharing options...
Reputable Contributor Silas Merlin Posted April 26, 2019 Reputable Contributor Report Share Posted April 26, 2019 Is it expected behaviour that when your use the reproject tool, if you uncheck "re-project color", then you lose vertex color on the original in the areas that you brushed with the reproject tool. Also, when you use the pose tool, you sometimes lose vertex color on the areas that you move. (reverts to the shader in both cases) Link to comment Share on other sites More sharing options...
Advanced Member druh0o Posted April 26, 2019 Advanced Member Report Share Posted April 26, 2019 (edited) 5 hours ago, lesaint said: It has really become a challenge to weld vertices using right click with the Add/Split tool, because of the popup menu. Doesn't anyone else have this issue ? Yeah, RMB popup window can be annoying. Even while navigating in viewport. And also, we already have Spacebar popup window, so there is kind of redundancy. But you can "pin" RMB window It will be always visible, but will never pop up again while pinned down. UPD: Oh, looks like I just found a bug (or an inconsistency in the interface). When you "pin" RMB window and then change selection mode, let's say from Faces to Edges, RMB window will switch to Spacebar window. Edited April 26, 2019 by druh0o Link to comment Share on other sites More sharing options...
Reputable Contributor Silas Merlin Posted April 26, 2019 Reputable Contributor Report Share Posted April 26, 2019 Yes, if you change tool too, for example Right click with Add/split > Pin menu > switch to select tool. Anyway, pinning it would have been a workaround... if it could be docked, or at least resized, minimized, or moved outside the viewport. But no, you can't do any of those things. Link to comment Share on other sites More sharing options...
Reputable Contributor Silas Merlin Posted April 27, 2019 Reputable Contributor Report Share Posted April 27, 2019 4.8.38-SL (GL64) Undo deselects Strip ? (even if you made several strokes with it), anyone has the same ? Link to comment Share on other sites More sharing options...
Reputable Contributor Silas Merlin Posted May 8, 2019 Reputable Contributor Report Share Posted May 8, 2019 Hello, are there plans to extend light baking to take metal/roughness into account ? Link to comment Share on other sites More sharing options...
Advanced Member pbowmar Posted May 9, 2019 Advanced Member Report Share Posted May 9, 2019 Hi Sergyi, Any luck with the Linux build? I'm happy to help test if that's needed. Lots of cool new things we're missing out on since the last Linux build... Cheers, Peter B 2 Link to comment Share on other sites More sharing options...
