• English
  • 3DCoat Documentation
    • Questions/Answers
  • Library
    • Training Tutorials
    • Multilanguage switcher
    • Questions/Answers
  • Library
      • Windows Panels
      • Painting Modes
      • Paint Tool Panel
      • Retopo tool panel
        • Voxel Adjust
      • Mod Tool panel
        • UV category
      • Shader Nodes Library
Material
1702 views 0
May 14, 2026
Overview: This category contains nodes for assembling, mixing, and breaking apart full PBR materials. Instead of working with individual color or float values, these nodes handle complete material structures containing Albedo, Gloss, Metalness, and other physical properties simultaneously.
GetColorProperty
Description: Extracts a specific color channel (e.g., Albedo) from a full material structure (Material).
Inputs and Settings:
  • colorProp (Dropdown): Options: ioAlbedoColor, ioReflectionColor, ioSheenColor, ioEmissive, ioSubSurfaceColor, ioMicroprotrusionsColor, ioTSNormal
  • Source (Material)
Outputs:
  • OutColor (3D Vector / Color)
GetFloatProperty
Description: Extracts a specific numeric channel (e.g., Metalness) from a full material structure (Material).
  • materialProperty (Dropdown): Options: ioOpacity, ioIridescence, ioAnisotropy, ioClearCoat, ioIOR, ioClearCoatGloss, ioVolume, ioMicroprotrusionsGloss, ioRefractionBlur, ioSpecularEdgePower, ioSubSurface, ioFlatSpecular, ioRefractionChromatic, ioAmbientOcclusion, ioMask, ioMicroprotrusions, ioMetalness, ioRefraction, ioRefractionMetalness, ioGloss, ioRoughness, ioSheen, ioDisplacement
  • Source (Material)
Outputs:
  • OutValue (Number (Float))
MaterialMix
Description: Smoothly blends two materials (Source1 and Source2) based on a grayscale mask (Mask).
  • Source1 (Material)
  • Mask (Number (Float))
  • Source2 (Material)
Outputs:
  • result (Material)
SimpleMask
Description: Universal mask generation node based on conditions (convexity, shadows, height, lighting). Very useful for smart materials.
  • ConditionType (Dropdown): Options: Always, MoreOnConcave, MoreOnConvex, LessOnConcave, LessOnConvex, MoreOnFlat, MoreOnCurved, MoreOnLit, MoreInShadow, MoreOnTop, MoreOnBottom, MoreOnSides, MoreOnBright, MoreOnMidtone, MoreOnDark, MoreOnPicked, MoreOnBumped, MoreOnDent
  • Mapping (Dropdown): Options: triplanar, UV, cilindrical, spherical
  • Contrast (Number (Float))
  • MaskDegree (Number (Float))
  • CavityWidth (Number (Float))
  • SurfaceColor (Color (RGBA))
  • PickedColor (Color (RGBA))
  • SurfaceDepth (Number (Float))
  • UVW (3D Vector / Color)
  • TriplanarTransition (Number (Float))
  • Scale (Number (Float))
Outputs:
  • result (Number (Float))
SimpleMaterial
Description: Creates or modifies a material, allowing adjustment of Albedo, Gloss, Metalness, Depth, and other PBR channels, overlaying them on a background material.
  • ColorMode (Dropdown): Options: ReplaceColor, ModulateColor
  • DepthMode (Dropdown): Options: Replace, Modulate
  • GlossMode (Dropdown): Options: Replace, Modulate
  • MetallMode (Dropdown): Options: Replace, Modulate
  • SecondColor (Dropdown): Options: None, ReflectionColor, SheenColor
  • ThirdColor (Dropdown): Options: None, SubSurfaceColor, MicroprotrusionsColor
  • OpacityFromAlbedoAlpha (Toggle / Checkbox)
  • DepthHighPass (Toggle / Checkbox)
  • BackGround (Material)
  • TexSharpen (Number (Float))
  • Color (Color (RGBA))
  • Depth (Number (Float))
  • HighPassLod (Number (Float))
  • DepthOffset (Number (Float))
  • Gloss (Number (Float))
  • Metall (Number (Float))
  • Anisotropy (Number (Float))
  • Sheen (Number (Float))
  • ReflectionColor (Color (RGBA))
  • SheenColor (Color (RGBA))
  • Refraction (Number (Float))
  • SubSurfaceColor (Color (RGBA))
  • RefractionBlur (Number (Float))
  • Chromatic (Number (Float))
  • Micro (Number (Float))
  • MicroColor (Color (RGBA))
  • MicroGloss (Number (Float))
  • ClearCoat (Number (Float))
  • CoatGloss (Number (Float))
  • SubSurface (Number (Float))
Outputs:
  • result (Material)
Layer
Math
