3D-Coat 3.1 updates thread
toothpaste brush crash sometimes. dont forget to save your work :)
I tried it extensively... no crashes...
Can you try 32-bit version and send me bugreport if it will hapen? It produces more readable crash reports...
Юзаю 32 бинтную без cuda с /3gb
Репорт ниразу не получилось сделать, просто закрывается после долгих раздумий.
Вобщем ситуация возникновения бага приблизительно следующая: создаю несколько объектов разной плотности сетки (ну это нормальное состояние для любой модели) и когда использую toothpaste, начиная строку на 1 объекте и продлевая дальше по поверхности другого происходит этот креш гдето в 1 случае из 10. Особенно если конец кисти "проваливается" между объектами далеко от исходной точки, сильно вытянувшись. С muscule tool и snake такого не происходит.
There are three different muscle types you can select in top menue...second one is what you want...
Thanks, I will have a look! :)
"Rasp-file tool done. It looks closely to 2D-paint nut acts as rasp-file. Inverse action - filling holes under plane."
about 9 hours ago from TweetDeck...
Andrew would it be possible to give us a preview of the new tools/functions you create (like rasp tool) by taking a screenshot and posting it here. :)
Это другое дело :)
Щас найду и пофикшу.
Rasp-file demo:
http://screencast.com/t/OXGvj9ko
Your new rasp-file is GREAT! I need it NOW. :-)
And while I agree with others that "Toothpaste" is a splendid name for that tool, I don't think that "Rasp-file" is such a good name . . . "Flattener"? "Leveller"?
Oh wow I didn't realize that tool's name is rasp-file, I thought it was just Rasp until I checked my Twitter feed. I don't think that works at all. It sounds like it does something with the .3B file or something and I think would be confusing. Perhaps Sliver or Slice?
Maybe Vox Plane would be a more appropriate Name, A Rasp is a course Grating file that would not create a smooth surface like that.
True of course! But in 3DC it is all dependent upon your pen alpha, so you could have a rough surface or smooth.
