Boroda, I did the same ! I think this "Release Candidate" runs in trial until the full release next week,then if like me you bought 3.7 with free 4 upgrade it will sort it self out....I hope.
What new shader previews? are they a bit different? I guess Ive never really looked at them that closely... :wacko:
Hello.
I've just installed v4 RC00 and my serial number stopped working. I enter it and click register. Website shows that my number is registered but the registration dialog is shown again without any error.
I reported the same problem to Andrew.
Andrew just let me know that the old keys won't work on V4 and new ones will come out in a couple of days. I guess I have to go back out and redownload an older v4 beta and install it, again.
Just run it in trail mode (30 day trial).
Updated to RC01 (Win)
- Important! LC detils parameter changed to be in consistency with V3.7.18. Now it produces 2x more detils than before, othervice even maximal value 3.0 gives not enough details. Pay attention to that change, if you set hight value for LC details, decrease it twice. Default spacing adjusted a bit to produce more comfortaable result. This change needs your check if I have not broken comfortable sculpting feeing. If I do this change later it will be too hard to explain it to a wider auditory.
- brush option "rotate along stroke" improved a lot
- FipX/Y/Z fixed
- set of defult brushes/strips/masks updated
- Increse/Decrease 2X problem fixed
In the beginning i was sfraid
- Important! LC detils parameter changed to be in consistency with V3.7.18. Now it produces 2x more detils than before, othervice even maximal value 3.0 gives not enough details. Pay attention to that change, if you set hight value for LC details, decrease it twice. Default spacing adjusted a bit to produce more comfortaable result. This change needs your check if I have not broken comfortable sculpting feeing. If I will do this change later it will be too hard to explain it to wider auditory.
- FipX/Y/Z fixed
Sculpting feels fine on my side.
Version 3.x serialnumber is invalid when registering version 4.x beta. It keeps failing all the time. Is it supposed to work like that ?
Yes. This is being changed in the next few days. Just use this temporarily till all is straightened out.
The overall sculpt feeling is far superior to anything i was tested until now.
ty for that.
//help
I still see the old shader icons
How can i reset the icons preview without delete the old V4 folder ?
ty
Edited by carlosa
- FipX/Y/Z fixed
Thank you for the LC details being more consistent with v3.7.18. I was just going to write an e-mail to you about the problems with LC Detail slider settings. It also really effected larger brush stamps using the stamp tool from the e-panel. You could never get the detail to increase enough for a clear stamp. In fact in v3.7.18 you could go pass 10.00 manually. This was great for large brush stamps. Please if possible make it so we can go pass 10.00 manually again. This is very important for very large stamps using the stamp tools... Another reason is that you can keep the polygon count lower but stamps those nice looking details.
I will check the detail slider settings when the Linux version 4RC01 is released. I'm not testing the windows version as we have enough windows users to do that...
Hey,
I'm very excited to try out the new release candidate. I think Live Clay is starting to become more and more powerful.
Just my 2 cents, and I hope I'm not offending anyone, but I am not 100% thrilled with the 3D Coat branding, I think something like this would be cooler and also do a better job of showing 3D coats strengths...Booleans, layer based painting and texturing.
Again, this literally took me about 15 minutes to do in Blender and 3DC. But with a little more time, I think someone could make something a lot nicer.
post-3280-0-05848100-1369721915_thumb.pn
