Carlosan Posted September 29, 2017 Share Posted September 29, 2017 Can't confirm so far 3DC in full Screen mode but Win 7 1 Link to comment https://3dcoat.com/forum/index.php?/topic/22364-3dcoat-48-beta-testing-thread/page/6/#findComment-148398 Share on other sites More sharing options...
Andrew Shpagin Posted September 29, 2017 Author Share Posted September 29, 2017 12 hours ago, Rygaard said: Some help here.... I have already downloaded and reinstalled the program (disconnecting this time the anti-virus), but even then this boring behavior of AVG antivirus block and take the 3d-coat v4.8GL64C.EXE to quarantine. The DX version is working properly, but every time I try to do a Restore in AVG it allows me and when I try to open the program again it blocks 3DcoatGL64C .... What to do? Thanks Are you sure you downloaded latest build? Downloaded exe should be 3d-Coat-V4_8-03-64FX.exe I downloaded, installed, checked with all known antiviruses, this is report: https://www.virustotal.com/#/file/ad26a7a518822496430cb79b343d7bb82b32e08d4bffe3dcd9f6623b1ee20577/detection 2 Link to comment https://3dcoat.com/forum/index.php?/topic/22364-3dcoat-48-beta-testing-thread/page/6/#findComment-148399 Share on other sites More sharing options...
Contributor Michaelgdrs Posted September 29, 2017 Contributor Share Posted September 29, 2017 6 hours ago, druh0o said: can't confirm so far but Win 7 and using Backspace key to undo a point instead of Ctrl Z is also works as it should Many thanks for the reply , freezes on backspace as well , forgot to mention it. Must be the additional VR space i added that causes the continues auto save (even when autosave is disabled) and the freeze as well. All good , was going to format it anyway too many new hardware added , it logical to get issues. Many thanks for the testing and your time dr Link to comment https://3dcoat.com/forum/index.php?/topic/22364-3dcoat-48-beta-testing-thread/page/6/#findComment-148400 Share on other sites More sharing options...
Contributor Michaelgdrs Posted September 29, 2017 Contributor Share Posted September 29, 2017 (edited) Just had to share this!!!! AMAZING WORK ON 3D MODELLING with PRIMITIVES from the DEV team. Thank you so much for adding those. 1) Primitives 2) Select vertices 3)Transform 4) Split 5) DONE Then retopo to sculpt , do your sculpt details and bake 2 in 1 . This was made in around 10 minutes , 15 MAX , faster 3d modeller EVER USED SO FAR. Note to new users : DEFINITELY GO IN TO THIS PATH , it takes a bit of time to get used to it but once you get the hang of it IT ROCKS Note to the Dev team : AWESOME WORK SO FAR , IF possible 1) A bridge tool 2) more primitives!!!! THANK YOU SO MUCH. Hopefully i lower the different softwares i use in my main workflow thanks to 3D Coat. Edited September 29, 2017 by Michaelgdrs 5 Link to comment https://3dcoat.com/forum/index.php?/topic/22364-3dcoat-48-beta-testing-thread/page/6/#findComment-148401 Share on other sites More sharing options...
Advanced Member stusutcliffe Posted September 29, 2017 Advanced Member Share Posted September 29, 2017 2 hours ago, Andrew Shpagin said: Are you sure you downloaded latest build? Downloaded exe should be 3d-Coat-V4_8-03-64FX.exe I downloaded, installed, checked with all known antiviruses, this is report: https://www.virustotal.com/#/file/ad26a7a518822496430cb79b343d7bb82b32e08d4bffe3dcd9f6623b1ee20577/detection Thank you Andrew ...All seems good for me now. 1 Link to comment https://3dcoat.com/forum/index.php?/topic/22364-3dcoat-48-beta-testing-thread/page/6/#findComment-148402 Share on other sites More sharing options...
Contributor Rygaard Posted September 29, 2017 Contributor Share Posted September 29, 2017 13 hours ago, Andrew Shpagin said: Are you sure you downloaded latest build? Downloaded exe should be 3d-Coat-V4_8-03-64FX.exe I downloaded, installed, checked with all known antiviruses, this is report: https://www.virustotal.com/#/file/ad26a7a518822496430cb79b343d7bb82b32e08d4bffe3dcd9f6623b1ee20577/detection Thank you very much Andrew Shpagin! The link to download (3d-Coat-V4_8-03-64.exe) is not the same that you give me. Now everything ok! Link to comment https://3dcoat.com/forum/index.php?/topic/22364-3dcoat-48-beta-testing-thread/page/6/#findComment-148414 Share on other sites More sharing options...
Advanced Member pbowmar Posted September 29, 2017 Advanced Member Share Posted September 29, 2017 I'm finding the Linux version of 4.8.03 noticeably slower than the Windows version. I have a dual-boot so hardware is identical but as an example: in Per-Pixel mode, load the Robot -turning off and on AO and the other auto-gen layers takes under 1 second on Windows, well over 3 seconds on Linux OpenGL mode on both Win and Linux, GeForce 960GTS, new drivers on both Win and Linux Have I missed a setting or optimization? Cheers, Peter B Link to comment https://3dcoat.com/forum/index.php?/topic/22364-3dcoat-48-beta-testing-thread/page/6/#findComment-148422 Share on other sites More sharing options...
Advanced Member BurrMan Posted September 30, 2017 Advanced Member Share Posted September 30, 2017 So key combo for tool settings adjustment = nothing is "red for depth"... "Shift is Green for smoothing" and Ctrl is "Blue for ??? Falloff????" Currently blue is duplicating as "Depth" Link to comment https://3dcoat.com/forum/index.php?/topic/22364-3dcoat-48-beta-testing-thread/page/6/#findComment-148428 Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted September 30, 2017 Reputable Contributor Share Posted September 30, 2017 38 minutes ago, BurrMan said: So key combo for tool settings adjustment = nothing is "red for depth"... "Shift is Green for smoothing" and Ctrl is "Blue for ??? Falloff????" Currently blue is duplicating as "Depth" Blue just indicates that the action is Inverted (indents rather than extrudes) Link to comment https://3dcoat.com/forum/index.php?/topic/22364-3dcoat-48-beta-testing-thread/page/6/#findComment-148429 Share on other sites More sharing options...
Member unity2k Posted October 1, 2017 Member Share Posted October 1, 2017 (edited) Regarding the Applink; once I have a Voxel object in 3DC and I want to send it back to Blender in my case, the File menu item to do so reads as, "BringVoxelsBackToApp" - just like that without spaces. Could this be changed to something like, "Send Mesh Back to App"? This is on 4.8.0.3 under Windows 10 Edited October 1, 2017 by unity2k added extra data Link to comment https://3dcoat.com/forum/index.php?/topic/22364-3dcoat-48-beta-testing-thread/page/6/#findComment-148468 Share on other sites More sharing options...
Member bocs Posted October 1, 2017 Member Share Posted October 1, 2017 reported 2 years ago...Status still "New", and still broken in 4.8. http://3dcoat.com/mantis/view.php?id=1992 Does nobody use curves? 2 Link to comment https://3dcoat.com/forum/index.php?/topic/22364-3dcoat-48-beta-testing-thread/page/6/#findComment-148469 Share on other sites More sharing options...
Taros Posted October 2, 2017 Share Posted October 2, 2017 Bug: Background->Ref-image can not be replaced, if using the same file name for replacing image. How to reproduce: 1. Create a background image: f.e. myimage.png 2. Set it to one of the axis in 3DC and close guides. 3. Edit myimage.png in your external program (photoshop f.e.) and replace the origin file with the update. 4. Edit image placement in 3DC and try to load the new version of myimage.png. -> No changes. 3DC seem to use the file in the cache instead of reloading it from disk. The only workaroud is to save myimage.png using a new name. This happend to alphas and stencils in the history too. I hope it was fixed there. Have not tried it. Can someone reproduce this? Best wishes Chris Link to comment https://3dcoat.com/forum/index.php?/topic/22364-3dcoat-48-beta-testing-thread/page/6/#findComment-148509 Share on other sites More sharing options...
Advanced Member druh0o Posted October 2, 2017 Advanced Member Share Posted October 2, 2017 yes, i have the same behavior for the ref image Link to comment https://3dcoat.com/forum/index.php?/topic/22364-3dcoat-48-beta-testing-thread/page/6/#findComment-148515 Share on other sites More sharing options...
Advanced Member Grimm Posted October 2, 2017 Advanced Member Share Posted October 2, 2017 I'm having a problem with this latest version, no smart materials show up. Do I need to do an extra step? I did run the copy data from the previous version, but not even the smart materials that I created before have shown up. Link to comment https://3dcoat.com/forum/index.php?/topic/22364-3dcoat-48-beta-testing-thread/page/6/#findComment-148517 Share on other sites More sharing options...
Carlosan Posted October 2, 2017 Share Posted October 2, 2017 Are you opening the app from the default alias or from old shortcut in desktop ? Link to comment https://3dcoat.com/forum/index.php?/topic/22364-3dcoat-48-beta-testing-thread/page/6/#findComment-148518 Share on other sites More sharing options...
