3DCoat 2021 Open Beta test !
Not sure if anyone else is having this problem.
Is the "Vox Clay" tool broken if you select the smallest sphere from the "Voxel Sculpting" page selection.
I updated the first post, inserted the license file there to prolong the trial.
  • Thanks 2
Using Voxel mode  > ClayEngine> Vox.Buildup my computer freezes, does this happen to someone else ?
B45: Cutting off a surface object with symmetry on more than two axes seems to break the objects. Sorry if already posted.
I have noticed that when switching to the Vox. Buildup tool the radius some times resets to 0. causing an out of memory Fatal Error if you try to sculpt/draw over a model rapidly.
1.05.21 B47
- Fixed little holes in voxel brush engine.
- Possibility to change mapping/thumbnails style in smart material via RMB for the whole folder.
- Possibly some changes announced in previous build was not present there, son now everything included there.
- The style of layers/tree items coloring changed.
  • Like 3
  • Thanks 2
Hello,
I would like to bring some attention to this behavior of the Strokes tool in the Retopo workspace. I am wondering if it works as intended3DCoatGL64_gobH7mPSL4.thumb.jpg.9e51c03001a5ef0b39c6ba08e11bbe47.jpg
To start, selecting Strokes tool → Selecting Closed Spine draw mode
I can draw a closed contour using the curves tool, then hitting enter will draw an (almost) closed contour stroke
This is well and good. But the same for an "open curve" like so:
Produces nothing:
If the tool is intended to perhaps only be used "normally" without curves, I can understand, but otherwise I would like to ask if it is intended
that the Curves can also be used with the Strokes tool.
This is more anecdotal, not pertaining to my question:
The reason I would attempt such a workflow, is I find drawing topology with the curves is much easier to see and modify, versus the default spline or brush-drawing behavior in the Strokes tool.
I am by no means visually impaired, but in my opinion, the thin green splines versus the strong red outline of the curves tools, the curves are much easier to see and better lends to pre-visualizing the geometry before it is placed.
The green splines also feel very "temporary" — Whereas curves remain in curves tree until deleted.
If I had the choice, drawing "Strokes" with the Curves tools would be the preferred option.
Thank you for your time and attention. 3DCoat 2021 is fantastic, congratulations to the entire team.
I havent tried B47 yet, but brush engine crashes the programe in B45 (not in earlier versions), not just vox build up but all of them. Screenfreezes and then often crashes out of 3dcoat
  • New Member
Extra parallel lines when switching from one monitor to another -
Hello,
I have downloaded the BETA 3DCOAT 2021. Just started the  program and was going through the quick start tutorial but when I  moved the program from my primary  window display to my  Huion tablet, (Kamvas GT 191-2), I get  at least three extra black parallel lines in the main interface window. When I hover over them  I get an arrow and the parallel lines can be moved to the left / right.  Furthermore, when I move and reset that actual brush panel on the right more black parallel lines appear. The lines remain even  after returning to the main monitor window.
On 4/28/2021 at 3:04 PM, Andrew Shpagin said:
We will give the beta license or make a special build, so don't worry about the trial end.
Are we going to see the Mac beta before release...?
Or will it just be released at final build.
Thanks.
Hi.
Curves do not stay at surface when editing curve points.
After shaving the modeling with Voxhide
Unwanted objects appear when using Vox Clay.
It worked fine in the V4 version.
I'm having similar issues with voxclay
Oh you are right.
Just using Vox Clay shows the symptoms :o
B44 using Epanel closed spline for cutoff.
Spline does not disappear even after reloading scene.
Hi,
  I have a bug when I want to use my stylus. You can see this video to see my issue. I only draw a couple of "2" but 3dcoat does not detect properly the end of the drawing and links the "2" even if my stylus does not touch the screen between each draw.
  I don't have the issue on 3dcoat v4.9.72.
https://vimeo.com/545674453/a557f482f7
P.
On 4/22/2021 at 12:22 PM, Silas Merlin said:
Yes, but you have to set everything up yourself and there is a learning curve.
Thanks a lot for the advice on this software. I just bought it tonight and it's going to make working in 3D Coat with the Wacom Cintique a lot easier, a lot more fluid and intuitive work flow.  It really works well; voice recognition has gone a long way
Edited by L'Ancien Regime
It becomes even more useful for performing a series of actions but there are pitfalls specific to 3d-Coat such as the inability to lock the ui. It is too easy to resize a panel by mistake, which makes using mouse clicks in your voice commands somewhat unreliable. A solution is to periodically restore workspace (with a voice command).
There is a discord server for the software with very reactive people helping you, (it is expected that you read the manual first).
I highly recommand having a separate profile loading at startup and performing a "stop listening" action. Otherwise any voice or sound in your workspace will trigger your commands.
Once VA is "not listening", you need to go into the options of your 3d-Coat profile and do something like this :
In this example, if I want to perform an action, let's say "toggle symmetry", then I need to say "Computer, toggle symmetry" for the command to be recognized.
This might sound cumbersome but it becomes rather natural with time, and removes the possibility of disasters occuring due to commands being performed by mistake due to ambient sounds.
Right now my favorite command is "interface". All the panels just disappear allowing me a totally empty viewing area. It's much nicer just to call up the various tools and other panels individually by name at need. And calling "interface" can toggle them all back in their pristine default form. This is going to go a long way in overcoming my distaste for the wading through the clutter of all the tools that really deserve to be learned and mastered. And it so much easier to have one meaningful word to remember over a bunch of abstruse key combinations to learn, you know, like in Blender and Zbrush. Click fests are the enemy of making art.
I like that too but the trouble with hiding the ui with TAB which is what I suppose you are doing, is that the options panel refuses to vanish under some circumstances, and it even appears when it was initially not present, in the render room for instance. I don't suppose this has changed in 2021 ?
So far that TAB command has worked. We'll see.
So if I just add that override listening if my spoken command begins with "computer" then I don't have to add "computer to every spoken command individually then?
That is correct
13 hours ago, RootBSD said:
Hi,
P.
if it can help for the debugging: my video was done on a Surface Book directly on the screen (not multi-screen).
This morning I was able to test on a XP-Pen (dual screen), and the issue is the same.
P.
Any idea when the face extrusion tools will be fixed in the modelling room?
I'm seeing some of the amazing demo videos of 2021 on YouTube but I cant understand how the author has created such models with this tool completely broken.
There are many issues with it as I described earlier still with V2021.B47:
  • Deselecting doesn't work when clicking off/away from the model
  • When selecting a new face the normal direction gizmo doesn't update unless I manually re-select the tool.
  • If I have all faces selected while I have the free move selected and click off screen (my other monitor) the objects moves to a random position in space sometimes VERY far from the original position.
  • Most of the extrude tools just move faces rather than actually extrude them. As far as I can tell only 'Normal Extrude' works partially, the others (smart extrude etc) do nothing useful.
For me It's probably the most useful tool (or it would be) in the room's toolset, but at the moment it's completely broken. This is preventing me from even starting to get into detail on a more complex model as the basic 3d modelling process is step one in creating anything.
Is no one else seeing these issues?
Cheers
Edited by Grimmy
To make Extrude, press Enter.
Has been working on the Transform tool for a long time.
With the Smart Extrud tool, you can move, rotate and scale.
Yes, thanks. I know that hitting enter commits the extrude but after you extrude once and select other faces the gizmo remains in the same place as the old extrude. The other problems I mention still exist.
Also, hitting enter is a very cumbersome way to commit the extrude (it's the opposite side of the keyboard to where most hands are resting (on the left side)) and would be far quicker to do something like double click/right click (Ideally something that doesn't require a keyboard shortcut)  or have an icon on the gizmo that commits the extrude.
Actually having said that I think the commit should just happen automatically and maybe holding shift or something takes you temporarily to the transform tool so you can tweak the position after if you need to...otherwise just dragging again creates another extrude.
Obviously this is a design decision but I've tried using the tool as it is many times to create simple extruded shapes, but it really feels very clunky (unusable in fact) for what should be a rapid building experience.
What Tool are we talking about?
You write - but it really feels very clunky (unusable in fact) for what should be a rapid building experience.
Why is he bad?
Thank.
  • New Member
I am way too excited for this version of the application. My favorite addition is the low poly modeling room (Where I have been playing!). I hope transitioning between rooms is streamlined as well (Rather than treating them as separate applications, it would be nice to be able to transfer directly between them. Maybe you could before and I just never figured it out!).
An issue I found almost immediately in the Low Poly room:
Reproduction steps:
1: Create a default cube (Where it all begins)
2: Select 3 of the top faces (It was an accident, but whatever finds the edge cases, right?)
3: Rotate the selected faces (Toward the unselected face. Again... accident. Getting used to the tool, haha)
4: Use the Spine tool and pull the selected faces out a few times into a loop (Kind of like the top of a lock)
5: Try to undo it all.
