  • 3DCoat Developer
Posted
2 hours ago, Tubor said:
The model file has been uploaded and can be tested
  • Replies 3.9k
  • Created
  • Last Reply
Top Posters In This Topic
  • Elemeno
    427
  • Andrew Shpagin
    249
  • Silas Merlin
    185
  • 3DCoat Developer
Posted
On 11/29/2021 at 1:53 AM, animk said:
Update: I replaced the "LinuxLibs" folder with the one from 2021.31, now it works.
New build "3DCoat 2021.71" for Linux should run with its own "LinuxLibs" (3 files). Please check that:
https://pilgway.com/~sergyi/links-Linux.html
Posted
sphere line tool bugged. I dont get it, why old tools that were working well many years got broken? this is so frustrating
  • 3DCoat Developer
Posted
17 hours ago, Tubor said:
Carlosan Andrew Shpagin  digman
ps:At that time, I tried to increase the density of the rhizome selection area, and the result was slightly better, but it was still not completely effective. If the number of topological grids increases, the software will stop working. In addition, the "instant mesh" has been tested. The speed and quality are better than the quality of automatic topology, but the rhizome head still can not give the correct result. . Looking forward to your test
Thanks for file. Understood the reason, fixed, now getting this with "Voxelize" option:
  • 3DCoat Developer
Posted
I tried sphere + lines mode, on first glance looks like all is OK there. Please describe in words what exactly is wrong.
Posted
i got the same issue
Posted
Since Andrew found a problem and fixed it, I will await a new build to test the file.
Posted (edited)
Я попробовал режим сфера + линии, на первый взгляд кажется, что там все в порядке. Пожалуйста, опишите словами, что именно не так.
Он имеет ввиду скорее всего  , что если объекты на разных слоях , то они не привязываются  .
Edited by Евгений
Posted
The Sphere tool works differently between V4 and 2021 versions.
  • Thanks 2
Posted (edited)
Gorbatovsky Andrew Shpagin digman
Thank you very much, mine also succeeded, thanks again
PS:72 version does not require any additional settings, the effect is almost perfect
Edited by Tubor
Posted
Points of sphere tool get offseted.  So place where you actually click dont  match with sphere line position.
Posted
sphere tool bugged even if you use curve. basically there is no way to add lines beetween meshes now it is completley broken.
Posted
Re: Autopo @Andrew Shpagin
To me the mesh has to be prepared thoroughly by the user before autopo.
I think you are trying to do that automatically in the autopo dialogue by offering "voxelization" option.
However, I believe that is not enough to ensure that problems are fixed.
could you try this :
-voxelize
-increase voxel resolution
-fill voids
-turn to surface
-objectify (and delete small parts)
-close holes
This should cover many possible issues, I think.
Posted
hey quick question, would it be possible to add the brush rotation option inside the tool parameter brush parameters? just having it there directly would be really great.
also maybe having a random flip x and y axis for the brush in the jitter, a bit like photoshop have, its really great to get some randomness when you sculpt details or ust 2d paint.
thanks
