Contributor BeatKitano Posted June 4, 2017 Contributor Report Share Posted June 4, 2017 The original idea of freeform sculpting was to allow the freedom of not having to worry about topology, experiment, and if the result was good enough, push it the extra mile to the finish line. With this roadblock it's still a dream. So plan ahead is not acceptable. 3 Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted June 4, 2017 Contributor Report Share Posted June 4, 2017 3 hours ago, Tony Nemo said: What of a switch to voxels that accurately calculates the needed resolution? Best workaround: plan ahead. The idea is good, but I think there's a good chance that the voxel density required for this kind of "lossless" conversion in some cases would be so high that it would lead to frequent system instability caused by workstations running out of RAM. Or viewport freezing on low end cards due to insane amount of triangles queued for rendering. A total overhaul of 3D Coat's surface booleans system might be the only way to go. SideFX managed to pull off a similar task. They ditched their old cookie operator and completely rewrote boolean ops. The result is a boolean operator that I have yet to see failing a given task. On my feature wish list for the sculpt room, this overhaul is a #1. 1 Link to comment Share on other sites More sharing options...
Member Speike-Styles Posted June 4, 2017 Member Report Share Posted June 4, 2017 (edited) 2 hours ago, ajz3d said: The idea is good, but I think there's a good chance that the voxel density required for this kind of "lossless" conversion in some cases would be so high that it would lead to frequent system instability caused by workstations running out of RAM. Or viewport freezing on low end cards due to insane amount of triangles queued for rendering. A total overhaul of 3D Coat's surface booleans system might be the only way to go. SideFX managed to pull off a similar task. They ditched their old cookie operator and completely rewrote boolean ops. The result is a boolean operator that I have yet to see failing a given task. On my feature wish list for the sculpt room, this overhaul is a #1. I believe that this is the only right way 3DC should continue. I've been testing SideFX since it's release and it is pretty interesting how they solved the ( Cache ) Part and I love it! With C4D it`s a beast ( Zero Lags, bugs Yay!) I would really like to see the Developers of 3DC to take action to what the community is asking for instead of leaving us in the cold. Sorry for being harsh, but you guys really need to focus on repairing the bugs and stop adding new ones. Still good job with your Renderman Plugin ( not needed, but ok. ) The 3DC community from Beginner to Professional can use your Product with a speed up workflow, but the Program needs some cleaning. I myself have slowed down fighting the frustrations with 3DC bugs and errors. It feels very slapped together and I am hoping for the day a clean and (True Stable Version ) to come out.. It would be real nice to see Pilgway grow as a Strong tree and not melt with the wrong melting cheese.. ( if you understand the metaphor) Edited June 4, 2017 by Speike-Styles 2 Link to comment Share on other sites More sharing options...
Member Frimasson Posted June 5, 2017 Member Report Share Posted June 5, 2017 9 hours ago, ajz3d said: The idea is good, but I think there's a good chance that the voxel density required for this kind of "lossless" conversion in some cases would be so high that it would lead to frequent system instability caused by workstations running out of RAM. Or viewport freezing on low end cards due to insane amount of triangles queued for rendering. A total overhaul of 3D Coat's surface booleans system might be the only way to go. SideFX managed to pull off a similar task. They ditched their old cookie operator and completely rewrote boolean ops. The result is a boolean operator that I have yet to see failing a given task. On my feature wish list for the sculpt room, this overhaul is a #1. + 1000 Link to comment Share on other sites More sharing options...
Member Mr.Panka Posted June 5, 2017 Member Report Share Posted June 5, 2017 hello, It would be nice to have a release note for the Mac & Linux version too. It's hard to know if any of the bugs are solved (no loading bar, incremental rendering not working on Retina display, non-US keyboard not recognised). Also, Is it possible to have an shader for emissive light ? (I know you can do it with smart materials, it would just be a little faster in some cases). Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 5, 2017 Reputable Contributor Report Share Posted June 5, 2017 23 hours ago, ajz3d said: The idea is good, but I think there's a good chance that the voxel density required for this kind of "lossless" conversion in some cases would be so high that it would lead to frequent system instability caused by workstations running out of RAM. Or viewport freezing on low end cards due to insane amount of triangles queued for rendering. A total overhaul of 3D Coat's surface booleans system might be the only way to go. SideFX managed to pull off a similar task. They ditched their old cookie operator and completely rewrote boolean ops. The result is a boolean operator that I have yet to see failing a given task. On my feature wish list for the sculpt room, this overhaul is a #1. I've been waiting for 4+ yrs for Sculpt Layers, and it has one of the highest levels of community support on Trello, and even this forum. Andrew is supposedly focused on the Paint workspace, so who knows when he'll ever get back around to the Sculpt and Retopo workspaces. Link to comment Share on other sites More sharing options...
Member tartinebrule Posted June 6, 2017 Member Report Share Posted June 6, 2017 On 5/26/2017 at 0:22 PM, tartinebrule said: Still no luck producing a build for Linux that would finally allow us to be on par with windows in terms of feature and bug fix? 1 come on... I made it easy for you, just copy paste in a terminal : gcc -o 3dcaot 3dcoat -I Thanks! T. Link to comment Share on other sites More sharing options...
Advanced Member Mystical Posted June 7, 2017 Advanced Member Report Share Posted June 7, 2017 Think I found a new bug in 4.7.29 with the brush/aitrbrush tool in the paint room. If I am using the brush tool in stamp mode and I apply color/normals to my model in the texture editor view (2D view) it seems to level artifacts all over before I let go of the mouse button. Trying to hit the undo key does not remove these artifacts either. I have to manually paint them away. Link to comment Share on other sites More sharing options...
Advanced Member tokikake Posted June 9, 2017 Advanced Member Report Share Posted June 9, 2017 (edited) Hi I happend to find some metalness, and color (Alberto) seems not restrict correctly, with icon or layer option. 1 load obj in Paint room, I set new layer for metalness , color, and roughness. 2 I set metalness (black and white) on metalness layer, (color wihte some part), set all other opacity as zero. but metalness opacity as 100% about this layer. 3 In texture editor, I set view as color. to see diffuse color texture. I believe it should be perfect newtral grey, but actually the color seems effected by metalness too. 4 Then I try to erase "color only" from Top menu>Layers>erase unfrozen part., but set Normal and glossy channel disable. (by icons) to restrict erase only about color. 5 now it seems remove "color" from metalness layer, but at same time it remove all metalness white color. then fill black again. through this step, I set layer visible only about metralness and Layer zero. then other layer cause no effect. and I only modify texture on metalness lyaer. If metalness will not be separated from color channel? Edited June 9, 2017 by tokikake add detail more Link to comment Share on other sites More sharing options...
Advanced Member tokikake Posted June 9, 2017 Advanced Member Report Share Posted June 9, 2017 Ah sorry I could confirm, when I export color map it seem not effected by metal layer. I believed 2d texture editor with color mode, may show color which not effected by Metalness,(alberto) but it seems count metalness as same as smoth shading, then it not matter. (though I hope if there will be option (alberto color only option), to quick see current alberto map which not effected metalness and roughness, without change metalness opacity,. Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted June 9, 2017 Author Report Share Posted June 9, 2017 4.7.30 [beta] - Possibility to change resolution of texture, attached materials will be automatically resmpled. - a lot of problems related to attached materials fixed - correctly updated material ball in layer attachment preview. - square alphas support. - Problems of paste UV fixed. 7 Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted June 9, 2017 Reputable Contributor Report Share Posted June 9, 2017 (edited) 10 hours ago, Andrew Shpagin said: 4.7.30 [beta] - Possibility to change resolution of texture, attached materials will be automatically resmpled. - a lot of problems related to attached materials fixed - correctly updated material ball in layer attachment preview. - square alphas support. - Problems of paste UV fixed. Thanks a lot for the square alpha support. Folders for the Preset panel... hint hint... LOL... Edited June 9, 2017 by digman Link to comment Share on other sites More sharing options...
Member Thomas Cheng Posted June 10, 2017 Member Report Share Posted June 10, 2017 Hi, Thanks for adding square alpha support, but it looks like the soft edges of some square alpha are clipping to the circle a little at the corners. Link to comment Share on other sites More sharing options...
Member Thomas Cheng Posted June 10, 2017 Member Report Share Posted June 10, 2017 I tried a softer and more rounded corner alpha to illustrate it better. It is subtle, but there. Link to comment Share on other sites More sharing options...
Member Mr.Panka Posted June 10, 2017 Member Report Share Posted June 10, 2017 4.7.30 [beta] on Mac Shaders (except in "default" and "skins" folders) are not working anymore. When I try to use them, it display the default shader. 3Dc can't find Renderman. Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted June 10, 2017 Author Report Share Posted June 10, 2017 4.7.31 [beta] - better support of square alphas. Less clipped at edges. - All tools are correctly compatible with layers attacments. - merge down, apply blending are working correctly with "Replace depth" and materials attaching. 3 Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted June 10, 2017 Reputable Contributor Report Share Posted June 10, 2017 "better support of Square Alphas, Less clipped at edges" Good news as I was just going to post my test results showing the clipped edges problem. I will test today later and report back here with the results. Link to comment Share on other sites More sharing options...
Carlosan Posted June 10, 2017 Report Share Posted June 10, 2017 Select Layer0 Attach any smart material - the layer is visually filled Now detach the smart material - the layer keep filled by the smart material. --------------------------------- In the download file only the version GL is v31. DX still is version 30 1 Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted June 10, 2017 Contributor Report Share Posted June 10, 2017 I'M downloading .31 because I got this with .30: Painting caused a color change from 'skin' to purple and white (the colors are 'X' out but hard to see in this pic). Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted June 10, 2017 Contributor Report Share Posted June 10, 2017 I am having this from 28 or 29 i thought it was my drivers!!! Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted June 10, 2017 Reputable Contributor Report Share Posted June 10, 2017 (edited) The clipping is less but still noticeable at the bottom. Some alphas will revel it more than others. The higher your resolution the less noticeable but still there. A little more tweeking at the bottom. The top is much much better, i can at times see just a very tiny clip but I do not know if that can be worked more. That might be as close as you can get. Thanks for working on this... Edited June 10, 2017 by digman Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 11, 2017 Reputable Contributor Report Share Posted June 11, 2017 This is weird...after installing 4.7.31 and choosing to run the DX version, the app shows 4.7.30 in the initial splash screen and at the top of the UI. But, if you choose the OpenGL version, it is 4.7.31. Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 11, 2017 Reputable Contributor Report Share Posted June 11, 2017 Also, where is this square alpha support? I was in the process of recording a tutorial showing this new support, and 3D Coat made me look stupid. Glad it wasn't live at Siggraph or some public demonstration. Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 11, 2017 Reputable Contributor Report Share Posted June 11, 2017 I'm stumped. Tried to delete all the config files from the MyDocs/3dcoat 4.7 folder > re-install 4.7.30 and 4.7.31 and none of them work. Start with a cube or human character from splash screen > voxel sculpting = ZIP. ZERO. NO-GO. NADA. NIL. NOTHING. Everything outside the brush circle gets clipped. Link to comment Share on other sites More sharing options...
Member Thomas Cheng Posted June 11, 2017 Member Report Share Posted June 11, 2017 (edited) I had to delete my old square alpha and reimport it. It should automatically be applied by detecting and cropped to the edge of it. That is what worked for me. Edited June 11, 2017 by Thomas Cheng 1 Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted June 11, 2017 Reputable Contributor Report Share Posted June 11, 2017 (edited) 26 minutes ago, Thomas Cheng said: I had to delete my old square alpha and reimport it. It should automatically be applied by detecting and cropped to the edge of it. At that is what worked for me. 14 hours ago, digman said: The clipping is less but still noticeable at the bottom. Some alphas will revel it more than others. The higher your resolution the less noticeable but still there. A little more tweeking at the bottom. The top is much much better, i can at times see just a very tiny clip but I do not know if that can be worked more. That might be as close as you can get. Thanks for working on this... Ah yes! good find Thomas... My post is now incorrect. Once I imported the square alphas again, no more clipping. The alpha image no longer goes to the corners of the brush radius preventing the clipping... Edited June 11, 2017 by digman added picture 1 Link to comment Share on other sites More sharing options...
Carlosan Posted June 11, 2017 Report Share Posted June 11, 2017 //edit Solved in version 4.7.32 ----------------------------------------- Square Alphas test using simple cheker UV square image as Alpha. - The edges are not straight but rounded. - Using Strokes > Stamp Mode, cant drag outside the model to paint a bigger area. The mesh geometry is the limit for the LMB drag operation. Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted June 11, 2017 Reputable Contributor Report Share Posted June 11, 2017 (edited) 2 hours ago, Carlosan said: Square Alphas test using simple cheker UV square image as Alpha. - The edges are not straight but rounded. - Using Strokes > Stamp Mode, cant drag outside the model to paint a bigger area. The mesh geometry is the limit for the LMB drag operation. I tested and confirm this... I was mistaken in my first my first responding to Carlosan post.The regular stamp tool does not get curved but the drag stamp tool mode does... Edited June 11, 2017 by digman added picture Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted June 11, 2017 Reputable Contributor Report Share Posted June 11, 2017 (edited) Ah, square alphas, nice... Used the regular stamp with a alpha. Brush options set at fade on edge. Line up the model on the grid with snapping, Changed the views with the keypad. Not shown for quality, yes the motar is reversed plus no ending of the block pattern at the corners just do to the type of alpha. Cool to have square alpha support now. Edited June 11, 2017 by digman 1 Link to comment Share on other sites More sharing options...
Member Thomas Cheng Posted June 11, 2017 Member Report Share Posted June 11, 2017 (edited) I do notice that the OpenGL version doesn't seem to work with certain alpha brushes (can't use it unless I make the brush small and it still seems random when it wants to work or not), while the DX version works fine with it. Not sure if it is a driver issue or a bug in 3D Coat. Anyone else notices this? Edited June 11, 2017 by Thomas Cheng Link to comment Share on other sites More sharing options...
