can we get a pose tool that we can align inside the mesh like how the spline tool work and each section is parented to the mesh with automatic weight but each section can have the weights edited using a selection tool or brush... and smooth to extend the weights
and then the ball areas of the spline tool will be where you can rotate or move to pose the mesh
Edited by Elemeno
@ThomasJohann Brushes > add New brush pressing + key. Select > create using curves.
@oah1981 You mean  sculpt layer seems to be destroyed if you bake onto it ?
Hi
In 2021.22 the blend options do not work - I do have a video, but I am at the maximum upload limit for posts. Modulate and multiply cause the layer to vanish (to be clear the layer does not vanish - the mode makes the contents of the layer vanish as if fully transparent), the other blend modes just act as standard blend.
Thanks
Edited by oah1981
Polish request. In the sculpt tree layers panel, layers will show a "+" or "-" regardless if there is a child or parent. I think it should only show a "+" or "-" only if the layer has children. This way there is a clear distinction which layers have children and which layers don't. Layers.thumb.png.d4e2903e0b059b3056b41837e1ed106b.png
  • Like 4
There is one more thing I would like to ask about the layer window.
It's very old from V4...
Can you fix the problem that the layers are not performed one by one when doing 'Change Parent'?
If you want to move at once, you need to do a Change Parent on the topmost layer (of the selected one).
I agree with this opinion
In 2021.22, when I paint multiple smart materials, rust over metal, the first material(metal)'s going away as I select the second material(rust).
4.x is okay.
It's ok if I add new layer before I activate the second one, but new layer's going to be locked, I have to add further more layer to paint(or unlock that without care of horrible warning).
Actually I don't know this is bug or spec, would like to know best way.
  • New Member
Hi.
I have just now (30 minutes ago) purchased 3D Coat 2021 and the link in the email takes me to a page containing a link to download 2021.21 and my account page contains various versions of 2021 up to 2021.21 as the latest available.
I thought I would take a quick look on the forums to check that the latest version has any issues before downloading. I see that there is a 2021.22 version linked on this thread.
I'm just wondering which version I should download and why my account doesn't show 2021.22 ? Is it perhaps a Beta version ?
