I plans (after complete cleanup cycle) I plan to improve automapping to produce less count of seams.
1 hour ago, kain_ty said:
I see the same phenomenon with objects in BrassPipes.
I can place the SoftBrick, SoftBrickEdge, and SoftbrickSmall in the Default folder, but for the others, the model does not show up and only the green joints increase.
Please run 3DCoat, try to place "invisible" joints models, then exit, find file Documents/3DCoat-2021/log.txt and attach the file to the post or send me to andrewshpagin@gmail.com
In the case of KitBash, there was a strange behavior right after startup, so I'll report it here.
Start Menu > Select KitBash
Click on "model" in JointWindow
For some reason, it switches to the Curve tool.
Click on the Joints model again.
It switches to the Joints tool, and when I click on the main window, the green joints are placed.
For some reason, it switches to the Flatten tool.
That's all I've done until the end.
Translated with www.DeepL.com/Translator (free version)
Log.txt
Log.txt
Please select Surface mode in the start menu, empty scene. Then manually select the joints tool in the tools list. Click on some model in the Brass pipes. Ensure you are still in joints tool. Try to add pipe to scene. What happens?
I selected Surface Sculpting, activated the Jonts tool, selected the Brass_Fit_Straight model and placed it.
Again, only the green joints were placed.
Log.txt
Log.txt
I noticed some problems when joints activated from the voxel mode. It is solved, look next build. But if you already in surface mode, it works correctly on my side. Could be good to get fullscreen video, from the start menu. I need to see tool parameters and VoxTree panel.
I recorded it.
It's very comfortable with the available joint models.
This feature seems to have a lot of uses in map editors and other applications if painted models can be used.
If it is possible to create scenes with painted models, it would be great.
If it is possible to create a scene by placing painted models, I think the value as a rendering tool will improve dramatically, and I look forward to its future development.
4.08.21 2021.21
- Finally fixed the problem when the voxel object disappears if the second stroke starts.
- Problem of the "bulky" build tool is fixed, actually Build may work correctly only in Buildup mode, so this option was just removed, and now Build works always in Buildup mode.
- Falloff is taken into account in the voxel brush engine.
- Closing cross in start menu now works correctly.
- If the joints tool is activated from the joints thumbnails panel, the new surface object will be created, because joints may work correctly only in the surface mode.
- Text correcting system (by user) writes timestamp and author to the textual XML for ease of future merging. It is important for translation the text by multiple users, done now mostly because of Japanese user's requests.
Mac&Linux builds are in process, will be available soon as well for the 21 build.
  • Thanks 3
@SERGYI
This log should help with the crashing on bake issue. It seems like is has something to do with the sRGB profile. Some posts ive been seeing say it could be tied to PNG images:
Aug  4 12:35:54 pop-os touchegg[1306]: libinput error: client bug: timer event9 debounce short: scheduled expiry is in the past (-5ms), your system is too slow
Aug  4 12:35:54 pop-os /usr/libexec/gdm-x-session[2514]: (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-5ms), your system is too slow
Aug  4 12:35:57 pop-os systemd[2220]: tracker-extract.service: Succeeded.
Aug  4 12:35:58 pop-os touchegg[1306]: libinput error: client bug: timer event9 debounce: scheduled expiry is in the past (-8ms), your system is too slow
Aug  4 12:35:58 pop-os touchegg[1306]: libinput error: client bug: timer event9 debounce short: scheduled expiry is in the past (-21ms), your system is too slow
Aug  4 12:35:58 pop-os /usr/libexec/gdm-x-session[2514]: (EE) client bug: timer event9 debounce: scheduled expiry is in the past (-8ms), your system is too slow
Aug  4 12:35:58 pop-os /usr/libexec/gdm-x-session[2514]: (EE) client bug: timer event9 debounce short: scheduled expiry is in the past (-21ms), your system is too slow
Aug  4 12:36:05 pop-os dbus-daemon[2324]: [session uid=1000 pid=2324] Activating via systemd: service name='org.freedesktop.Tracker1.Miner.Extract' unit='tracker-extract.service' requested by ':1.2' (uid=1000 pid=2317 comm="/usr/libexec/tracker-miner-fs " label="unconfined")
Aug  4 12:36:05 pop-os systemd[2220]: Starting Tracker metadata extractor...
Aug  4 12:36:05 pop-os tracker-extract[344772]: Set scheduler policy to SCHED_IDLE
Aug  4 12:36:05 pop-os tracker-extract[344772]: Setting priority nice level to 19
Aug  4 12:36:06 pop-os dbus-daemon[2324]: [session uid=1000 pid=2324] Successfully activated service 'org.freedesktop.Tracker1.Miner.Extract'
Aug  4 12:36:06 pop-os systemd[2220]: Started Tracker metadata extractor.
Aug  4 12:36:07 pop-os org.gnome.Nautilus[344616]: libpng warning: iCCP: known incorrect sRGB profile
Aug  4 12:36:08 pop-os systemd[1]: systemd-hostnamed.service: Succeeded.
Aug  4 12:36:12 pop-os org.gnome.Nautilus[344616]: libpng warning: iCCP: known incorrect sRGB profile
Aug  4 12:36:23 pop-os kernel: [190172.749723] [UFW BLOCK] IN=enp4s0 OUT= MAC=01:00:5e:00:00:01:44:d4:53:7b:52:52:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=54745 DF PROTO=2
Aug  4 12:36:12 pop-os org.gnome.Nautilus[344616]: message repeated 2 times: [ libpng warning: iCCP: known incorrect sRGB profile]
Aug  4 12:36:33 pop-os org.gnome.Nautilus[344616]: The futex facility returned an unexpected error code.
8 hours ago, Silas Merlin said:
I have not tested but I think I don't need to : In 3d-Coat a paint object cannot be without UV's, therefore, if you have not marked seams/unwrapped before baking, 3d-Coat will do it for you.
I think this is perfect, no change needed in that respect.
Though you think it  work for you  but I think the  auto UV map not good clean uv. 3d coat generate auto-UV map for primitives in paint room when bake, but retopo mesh still not have any UV map.  (then generated UV map is not good clean uv which I epxect)  then after all I may need to send back with UV to retopo room and manually set seam to check it in retopo room.
If you check other modeling aprication  primitive witch come UV, you may understand why I expect it for 3d coat retopo  (and modeling room) primitives. even though I model complex one, as start point good UV is more easy to edit.  you may actually compare primitive default UV maps (blender).  and 3d coat auto un-wrap UV (when bake).  I suppose after all if 3d coat offer those default UV (or auto seam for those primitives)  you never complain it.
auto generated UV of UV sphere (in 3d coat)
cylinder
3d coat auto UV for cylinder
I may not need to add other UV for primitives. so I do not say 3d coat need to becom same , but simply hope to see clean default UV for primitives. without any work.
Windows version  20.21
Microvextex import into the paint room.
Render room renders the color of the model black in the render room.
Steps to reproduce:
From the New Menu. Choose  Paint w/deep displacement (Micro-Vertex)
Select the creature. Do one subdivision upon import.
Fill a color over the entire model.
Switch to the render room. Model is black.  Render room is using 3D Coat hardware.
Tested with just Real time render on and Real time render on with Screen space reflections and illuminations. Same result.
(Side Note: The model is black even if you fill with no color)
If you turn off real time render the color appears.
Uploaded picture is from the render room.
Steps to reproduce:
This happens on linux as well, specifically for Ubuntu 21.04:
Steps to reproduce:
New file > Big Sphere (Or any object) > Render room > Black model
