• English
  • 3DCoat Documentation
    • Introduction to 3DCoat
    • Getting started
    • Interface
    • Brush Components
    • Workspaces Rooms
    • Scripting & Core API
    • Questions/Answers
  • Library
    • Training Tutorials
  • Blog Posts
  • English English
    • Multilanguage switcher
    • Getting started
    • Interface
    • Brush Components
    • Workspaces Rooms
    • Questions/Answers
  • Library
  • Blog Posts
  • English English
  • Getting started
    • Activating 3DCoat
    • Startup error
    • Folders Structure
    • Import and Export
      • Blender 4.1 applink
    • Quick Start Menu
    • Navigation Panel
    • Camera and Navigation
    • Hotkeys
  • Interface
    • File
    • Edit
      • Preferences
    • View
    • Symmetry
    • Layers
    • Freeze
    • Curves
      • Curves editor
      • Fill with mesh layer
    • Windows
      • Windows Panels
      • Controls
    • Help
    • Room Customization
    • Modify or Create new Room
  • Brush Components
    • Brushes general use
    • Strokes
      • Curves Popup Menu
    • Brush Options panel
    • Strips Panel
    • Stencils Panel
      • Add new images or materials
    • Presets for Brush alphas
  • Free 3DCoatPrint
  • Workspaces Rooms
    • Paint
      • Painting Modes
        • Per Pixel Painting
        • Lock Normals
      • Paint Menus
        • Textures Menu
          • Texture Baking Tools
        • Bake Paint menu
        • The Color Picker
      • Top Bar for the Painting
      • The Layers Panel
        • The Blending Panel
      • Paint Tool Panel
      • Opacity & Transparency
      • Tweak tools
      • UV Top Bar
      • UV Left tool panel
      • UV Preview Panel
      • UV workflow example
      • Importing Into the UV Room
      • Exporting from the UV Room
      • Importing into Retopo Room
      • Retopo Mesh Menu
        • Virtual Mirror Mode
      • Strokes tool in Retopology
        • Select geometry
      • Retopo tool panel
        • Overall Purpose & Function
        • Tweak Tools
        • UV Tools
      • Poly Groups
      • Sculpt Tree
      • Sculpt Brush options
      • Brush engine
      • Geometry menu
      • Right-Click Menu
      • Shader
      • Voxel mode
        • Pure Voxel Sculpting
        • Density and Resolution
        • Clay Engine
        • Voxel Tools
        • Surface tools on Voxels
        • Voxel Adjust
        • Volumetric Painting
        • Voxel Objects Tools
      • Surface mode
        • Surface tools
        • Surface custom tools
        • Surface adjust tools
        • Surface Painting
        • Multi Level Resolution
      • Sculpt curves
        • Spline Curves
      • Vector Displacement
      • Transform tools
        • Transform
      • Primitives
      • Live Booleans
      • Commands for Sculpt room
      • Import to Sculpt Room
      • Render Panel Functions
      • Turntable
      • Workflow
    • Simplest
      • Mod Tool panel
        • Add Geometry
          • Selected
        • Tweak
        • UV category
          • UV: Selected and Commands
        • Entire Mesh
      • Blockout by Poeboi
    • Kitbash
    • Nurbs
      • Shader Nodes Library
PBM Channels
5343 views 3
May 13, 2026
1. Base Channels
  • Opacity
  • Emissive
  • AmbientOcclusion
  • Mask
2. Specular & Metalness
  • Metalness
  • Roughness / Gloss
  • IOR (Index of Refraction)
  • ReflectionColor
  • SpecularEdgePower
  • FlatSpecular
3. Refraction / Glass
  • Refraction
  • RefractionBlur
  • RefractionMetalness
  • SubSurface / Volume
  • SubSurfaceColor
5. Special Surface Effects
  • Anisotropy
  • Iridescence
  • EffectNormal
  • ClearCoat
  • ClearCoatGloss
  • Sheen
  • SheenColor
  • MicroprotrusionsGloss
  • MicroprotrusionsColor
How it Works
How to Use It
  • Navigate to the View Menu.
3 Yes  No
GPU Texturing
Per-Pixel Painting
