New Folders Structure
Really streamlined and logical as it was proposed.
Almost all now is split between two folders – data and UserPrefs.
- UserPrefs is user-created content.
- Data is sort of temporary stuff.
The folder in documents changed, now it is Documents/3DCoat-202x/
Even if the folders structure is changed it is compatible with the previous one.
As soon as 3DCoat detects some files copied to the new location in Documents from the old one, it will convert the files to the new structure.
Also, if you will install 3dcpack it will be installed correctly (except for presets that use old tools that are not present in the toolset).
So, to migrate from an earlier version you may copy folders from old versions to Docs/3DCoat-202x or create 3dcpack in the old version and install using the latest.
Migrating old v4 data to the newest versions
Use Migration Master to import your brushes, presets, smart materials from V4.
The 3DC_Brushes is quite extensive, so seemed to take a while, but then 3DC restarted with them added.
Warning: Not all presets are compatible
Create extensions
Using the File Menu to Create Extensions (for general users)
- Gather Your Assets: Create a folder on your computer containing all the assets you want to include in the extension, such as custom brushes, smart materials, textures, and scripts.
Create the Extension:
In 3DCoat, go to the File > Create extensions menu to start the process of packaging your assets.
Select Your Folder:
The tool will prompt you to select the folder containing your assets.
Generate the Package:
3DCoat will then create a distributable package in the .3dcpack file format.
Installing an Extension
- Install it: An extension is a
.3dcpackfile. You can install an external file by selecting File > Install extension in the File menu.
日本語
English
Українська
Español
Deutsch
Français
Русский
한국어
Polski
中文 (中国)
Português
Italiano
Suomi
Svenska
中文 (台灣)
Dansk
Slovenčina
Türkçe
Nederlands
Magyar
ไทย
हिन्दी
Ελληνικά
Tiếng Việt
Lietuviškai
Latviešu valoda
Eesti
Čeština
Română
Norsk Bokmål
