• Ελληνικά
  • Τεκμηρίωση 3DCoat
    • Ερωτήσεις και απαντήσεις
    • Εκπαιδευτικά Φροντιστήρια
    • Conditions Limiter
        • Autopo Baking guide
        • Autoretopology Guide
        • UV panel
        • Commands panel
        • UV panel
        • Commands panel
605 views 0
Add several images to a new folder.
– What if I have some set of images like the one in the pic? Is there a way to set them up in a folder structure that 3DCoat can import? They are only Albedo images for projection painting.
On Smart Material Panel, select Create New Folder, then press 3 dots icon.
Select the option: add an existing folder.
Navigate inside the folder content and select only the first pic. Press open.
Add existing materials folder.
Add the Smart materials from an existing folder. A new Materials folder with the same name will be created. Select at least one file to automatically add all the files from the folder to the list.
This is the complete list of aliases (at the end of the filename) used to recognize the texture usage:
Bump:
_DEPTH, _BUMP, _DEEP, _DISPL, _DISP, _DISPLACEMENT, _D
Normal map:
_NMAP, _NM, _NORMAL, _NORMALMAP, _NORM, _NORMALS, _N
Color:
_COLOR, _CLR, _DIFFUSE, _ALBEDO, _CL, _RGB, _DIF, _C
Gloss:
_SPEC, _GLOSS, _GLOSNESS, _GLOSINESS, _GLOSSNESS, _GLOSSINESS
Roughness:
_ROUGH, _ROUGHNESS, _R
Clip mask:
_MASK, _MSK, _MS, _CLIP, _ALPHA
Metalness:
_MET, _METAL, _METALL, _METALLICITY, _METALICITY, _METALNESS, _METALLNESS, _MT, _ME, _METL
Ignored:
_PREVIEW, _PREV, _TMB, _THUMBNAIL, _PRV, _AO, _OCCLUSION
The any of . – ~ may be used instead of the _ sign.
If any map is named with a space in the name, the texture is assigned as new Smart Material.
Tags:add imagesadd materialssmart materials
Smart Materials
Attach a Smart material to a layer
On This Page: [hide]
