• Suomi
  • 3DCoat dokumentaatio
    • Kysymykset ja vastaukset
    • Koulutusopasteet
    • Koulutusopasteet
Smart Hybrid
341 views 0
On 3DCoat 2025 and earlier a new technology was added to the set of Modeling tools: Smart Hybrid.
Features:
• It is an integration of different modeling methods
• Inside Smart Hybrid is a set of patches.
• There are many ways to create this model (patches)
– from a set of curves
– from a Low Poly mesh->Catmull-Clark Smoothing
– pre-created primitives Algorithm
– generate with tools (Swept, Conic)
– from selected surfaces
• It is incredibly flexible, with many graphs for editing
• It is smart, you can see if the joints are hard or smooth
• After creating the model, you can easily change the topology (InSet, Extrude, Subdivide)
• The model shows surfaces that can be changed by pulling the poles or parametric lines
Tools
Select: Selection of object or Point/Edges.
Create Smart Hybrid: The Smart Hybrid can to create from visible mesh.
Smart Hybrid Tool: The tool allow to edit mesh of Smart Hybrid and to create new mesh.
Smart Hybrid Extrude: The tool allow to extrude of selected faces of Smart Hybrid.
Smart Hybrid Transform: The tool allow to Transform of selected faces/edges/points of Smart Hybrid.
Smart Hybrid Offset: The tool allow to Offset of selected rectangle of faces of Smart Hybrid.
Smart Hybrid Alignment: The tool allow to Alignment the Boundary of selected rectangle of faces of Smart Hybrid.
Smart Hybrid SubDivide: The tool allow to SubDivide of faces of Smart Hybrid.
Smart Hybrid allows you to create
• Low Poly mesh
• Sculpt mesh
• Paint mesh
• Free Surface
• Solid
• Edge set can be extracted
What operations can be done with a Smart Hybrid object
• Subdivide
• Extrude
• Cheekbones
• Undercuts
• Deformation grid
• Surface Editing
Tags:modelingsmart-hybrid
Tweak
UV modpanel
