• Eesti
  • 3DCoat dokumentatsioon
    • Küsimused/Vastused
    • Koolitusõpetused
    • Koolitusõpetused
Startup error
1078 views 1
Issues with OneDrive installed
“3DCoat” is trying to create a user data folder (which contains user settings and assets) inside “C:\Users\USER_NAME\OneDrive\???????\3DCoat”.
That is incorrect. It should create it inside “C:\Users\USER_NAME\Documents\3DCoat”.
To workaround this problem:
Start > start typing “Edit the system environment variables” > Environment Variables… > System variables > New… >
Variable name: COAT_USER_PATH
Variable value: C:\Users\USER_NAME\Documents\My3DCoatData (specify your user name inside)
3DCoat not starting on my Cintiq
I drag the 3DCoat Window to my cintiq tablet to work on it. Still works great.
I close 3DCoat, and I try to start it up again, a window opens on my Cintiq but 3Dcoat stops responding, so all I can do is close the app.
The problem occurs if you move the application to 2nd monitor (Cintiq) and close it while on that screen ? If yes > then move the app back to your primary monitor, save document, close it, and it’ll relaunch.
Suddenly a huge bug occurred that made it impossible to enter on any room
Remove folder (or rename) Docs/3DCoat/UserPrefs/Rooms/CustomRooms.
This will remove local rooms settings. If you don’t want to lose it, find and remove all *.cpp files in that folder.
Crash using rectangle and vertex lasso stroke mode using Vox hide and Sphere tool
Have you seen this message sometimes?
In some cases huge object still may be created in case of improper plane position.
Tags:cintiqinstallstart error
1 Yes  No
Activating 3DCoat
Startup error Mac
