• Latviešu valoda
  • 3DCoat dokumentācija
    • Jautājumi/Atbildes
    • Apmācības pamācības
How to compile Spacenavd on non Ubuntu distro
881 views 0
by Sakru
So, i decieded to spend some time and get Spacenav working on non ubuntu based distro. Tried to adapt what i did on CL. This guide should work on other distros like Arch, Opensuse and Fedora.
Before you start, ensure that you have the following dependencies installed: Development tools (GCC, Make), CMake, X11 development libraries, libspnav.
For most distributions, you can install these dependencies using your package manager:
Fedora: sudo dnf install gcc make cmake libX11-devel libspnav-devel
Arch Linux: sudo pacman -S base-devel cmake libx11 libspnav
OpenSuse: sudo zypper install gcc make cmake libX11-devel libspnav-devel
1. Clone the Spacenavd Repository
git clone https://github.com/FreeSpacenav/spacenavd.git
cd spacenavd
2. Run CMake to configure the build
cmake.
3. Compile the source code
make
4. Install spacenavd
sudo make install
5. Set up and enable the spacenavd service
sudo nano /etc/systemd/system/spacenavd.service
Add the following content to the file:
[Unit]
Description=Spacenavd Service
After=network.target
[Service]
ExecStart=/usr/local/bin/spacenavd -d
Restart=always
[Install]
WantedBy=multi-user.target
6. Reload Systemd Deamn and start the service
sudo systemctl daemon-reload
sudo systemctl enable spacenavd
sudo systemctl start spacenavd
Ensure that spacenavd is running without errors:
systemctl status spacenavd
If you have any questions, feel free to ask.
Navigation using 3DConnexion devices
Stylus doesn’t work in sculpting
