Add Clusters: Use LMB to mark the cluster (UV Islands) center on faces. Click the cluster again to delete it.
Mark Seams: Mark seams on the UV-Map. CTRL+LMB unmarks a seam.
Edge Loops: Mark entire edge loops on the UV-Map. Use CTRL+LMB to unmark them.
UV Path: Put path along the shortest path (under certain criteria) between several points. Click to add points or split lines, use RMB, or double-click to remove points. Press ENTER to mark seams, and CTRL ENTER to delete seams. Use different criteria to adjust path flow.
Join Clusters: Hover the seam between the clusters and click to remove the whole seam and join clusters. If the highlighted seams are red, the resulting summary islands have self-intersections or too big square trash. If it is green, the summary island has no self-intersections, and square trash is no more than 1/2.
Tiếng Việt
English
Українська
Español
Deutsch
Français
日本語
Русский
한국어
Polski
中文 (中国)
Português
Italiano
Suomi
Svenska
中文 (台灣)
Dansk
Slovenčina
Türkçe
Nederlands
Magyar
ไทย
हिन्दी
Ελληνικά
Lietuviškai
Latviešu valoda
Eesti
Čeština
Română
Norsk Bokmål
