• 日本語
  • 3DCoatドキュメント
    • 質問と回答
    • トレーニング チュートリアル
  • 3DCoatドキュメント
    • 質問と回答
    • トレーニング チュートリアル
Render
1109 views 0
In this room, you can test your model and its textures in an environment much closer to a third-party rendering environment and create animated turntables and fly-throughs of your model and scene.
Also, all through the creation process, it is helpful to get a reasonable approximation of your rendered models and scenes without the added difficulty of exporting to 3rd party rendering applications.
You can add multiple colored light sources, adjust the depth of field of the camera, mitigate or accentuate shadow effects, and control how many rays are tracked in the final rendering.
Real-time rendering is also possible, so you can quickly and easily see the many possibilities of lighting, focus, and ambient occlusion from any angle.
Once your model is in the texturing phase, you can immediately view the results by simply defining your render settings and clicking the Render button on the Render panel.
When creating a portfolio of your work, it is often advantageous to include both “Turntable” and “Flyby” animations of your 3D sculptures and scenes.
Render stills or turntables and flythroughs at any resolution by rotating clockwise or counterclockwise with up to 32-bit-color information, and choose whether to include the alpha channel in your final rendering.
You also can upload your animated scenes directly to YouTube or Vimeo or upload a screenshot to the Pilgway servers to share with other users, all from the 3DCoat Help menu.
Parameters Panel Explained
3DCoat’s internal Render Room provides all these convenient and fast methods for viewing, evaluating, and exporting realistic views of your models and scenes.
Render Menu
Screen space reflections and Global Illumination
You can also render Screen space and Global Illumination.
Render room > Realtime render can’t be selected: This is because of the new StemCell Certification feature.
It needs to be disabled in the Render settings.
Renderman Integration: This video provides a brief overview of the Renderman integration in 3DCoat 4.8 (as of build 4.8.04). It is still a Work in Progress at the time of this recording, but highly functional/usable. Stay tuned for updates to the toolset.
HDR Environment Map Options: This video covers several new options for previewing and utilizing HDR environment maps within a scene for lighting and the background.
Render room, intro to 3DCoat: Artstation: https://www.artstation.com/tenitsky
Gumroad: https://gumroad.com/tenitsky
New Renderer possibilities in 3DCoat: Procedural Environments and Post Effects Video demonstrates new Renderer possibilities in 3DCoat.
Exporting from the Sculpt Room
Comparison of different roughness values
