• English
  • 3DCoat Documentation
    • Introduction to 3DCoat
    • Getting started
    • Interface
    • Brush Components
    • Workspaces Rooms
    • Scripting & Core API
    • Questions/Answers
  • Library
    • Training Tutorials
  • Blog Posts
  • English English
    • Multilanguage switcher
    • Getting started
    • Interface
    • Brush Components
    • Workspaces Rooms
    • Questions/Answers
  • Library
  • Blog Posts
  • English English
  • Getting started
    • Activating 3DCoat
    • Startup error
    • Folders Structure
    • Import and Export
      • Blender 4.1 applink
    • Quick Start Menu
    • Navigation Panel
    • Camera and Navigation
    • Hotkeys
  • Interface
    • File
    • Edit
      • Preferences
    • View
    • Symmetry
    • Layers
    • Freeze
    • Curves
      • Curves editor
      • Fill with mesh layer
    • Windows
      • Windows Panels
      • Controls
    • Help
    • Room Customization
    • Modify or Create new Room
  • Brush Components
    • Brushes general use
    • Strokes
      • Curves Popup Menu
    • Brush Options panel
    • Strips Panel
    • Stencils Panel
      • Add new images or materials
    • Presets for Brush alphas
  • Free 3DCoatPrint
  • Workspaces Rooms
    • Paint
      • Painting Modes
        • Per Pixel Painting
        • Lock Normals
      • Paint Menus
        • Textures Menu
          • Texture Baking Tools
        • Bake Paint menu
        • The Color Picker
      • Top Bar for the Painting
      • The Layers Panel
        • The Blending Panel
      • Paint Tool Panel
      • Opacity & Transparency
      • Tweak tools
      • UV Top Bar
      • UV Left tool panel
      • UV Preview Panel
      • UV workflow example
      • Importing Into the UV Room
      • Exporting from the UV Room
      • Importing into Retopo Room
      • Retopo Mesh Menu
        • Virtual Mirror Mode
      • Strokes tool in Retopology
        • Select geometry
      • Retopo tool panel
        • Overall Purpose & Function
        • Tweak Tools
        • UV Tools
      • Poly Groups
      • Sculpt Tree
      • Sculpt Brush options
      • Brush engine
      • Geometry menu
      • Right-Click Menu
      • Shader
      • Voxel mode
        • Pure Voxel Sculpting
        • Density and Resolution
        • Clay Engine
        • Voxel Tools
        • Surface tools on Voxels
        • Voxel Adjust
        • Volumetric Painting
        • Voxel Objects Tools
      • Surface mode
        • Surface tools
        • Surface custom tools
        • Surface adjust tools
        • Surface Painting
        • Multi Level Resolution
      • Sculpt curves
        • Spline Curves
      • Vector Displacement
      • Transform tools
        • Transform
      • Primitives
      • Live Booleans
      • Commands for Sculpt room
      • Import to Sculpt Room
      • Render Panel Functions
      • Turntable
      • Workflow
    • Simplest
      • Mod Tool panel
        • Add Geometry
          • Selected
        • Tweak
        • UV category
          • UV: Selected and Commands
        • Entire Mesh
      • Blockout by Poeboi
    • Kitbash
    • Nurbs
      • Shader Nodes Library
Import and Export
5572 views 0
Use 3DCoat’s comprehensive set of tools to seamlessly sync your models with all of your external 3D applications. Import “raw” mesh data or models with UVs intact. External models can be imported as reference meshes or for creating all new topologies ready for texturing.
Importing and exporting in 3DCoat is a broad topic -and encompasses specific assets which can be imported- and which can only be understood in the context of which Workspace you are importing them into. Some asset imports only make sense when you take into consideration the Room in which they primarily function.
We’ll show you which menu you should use for which type of asset import & export and which Room you should be in when you import these specific assets.
Importing into different Workspaces
1. Importing into the Sculpt workspace
2. Importing into the Retopo workspace
3. Importing Into the UV workspace
4. Importing Into the Paint workspace
Exporting from different Workspaces
1. Exporting from the Sculpt workspace
2. Exporting from the UV workspace
3. Exporting from the Paint workspace
4. Exporting from the Tweak Room
Quixel Megascans
You can use your Megascan library materials in 3DCoat by importing them as Smart Materials. First, download the materials from the Megascan library in a format compatible with 3DCoat, such as textures or images.
Fully Compatible With Quixel Materials.
If you download a Quixel material into “Downloads”, 3DCoat will automatically notify you that new material has been downloaded and will offer you to install it as a material or shader.
Then, import these materials into 3DCoat using these steps:
If you download a zipped Quixel material into the default “Downloads” folder, 3DCoat will automatically notify you that a new material has been downloaded and will offer you to install it as a material or shader.
Or Import it using the command “File > Install > Install Quixel Asset as Smart Material.”
Once set up, you can apply these materials to your models using 3DCoat’s texturing tools.
Import Textures migrate manually
3DCoat 2022 has a completely new folder structure. Really streamlined and logical as it was proposed.
Almost all now is split between two folders – data and UserPrefs.
As it is logical, UserPrefs is user-created content.
Data is sort of temporary stuff.
The folder in documents changed; now it is Docs/3DCoat-2024/.
Even if the folder structure is changed, it is compatible with the previous one.
As soon as 3DCoat detects some files copied to the new location in Documents from the old one, it will convert the files to the new structure.
Also, if you install 3dcpack, it will be installed correctly (except for presets that use old tools that are not present in the toolset).
So, to migrate from the earlier version, you may copy folders from old versions to Docs/3DCoat-2021 or create 3dcpack in the old version and install it using UI.
Tutorials
Quick Tip: Fixing Low Polygon Mesh Imports
Installing Brush Alphas This video is part 1 of 2 that covers the various methods of installing Brush alphas, individually or as brush packs. This includes a brief demonstration of creating your own brush alpha with a 3D model.
The link to the free XMD brush pack for 3DCoat is below:
https://gumroad.com/mdunnam?#RogB
Installing and Creating 3dcpack Files
Surface Paint: Exporting: This video continues the PolyPaint demonstration by covering an example of exporting the object directly from the Sculpt Room to a 3D application (3ds Max, in this case)… no UVs… no Retopo work.
Yes  1 No
Tablet on Window
Applinks in 3DCoat specifications
