• Latviešu valoda
  • 3DCoat dokumentācija
    • Jautājumi/Atbildes
    • Apmācības pamācības
        • Autopo Baking guide
        • Autoretopology Guide
Conditions (Height/Color) Limiter
627 views 1
Another important feature on the Top Bar is the Height/Color Limiter or Conditions.
Conditions can be accessed by clicking the Top Bar.
Height/Color Limiter Conditions
Select how the depth, color, and Gloss of your brush strokes are affected by colors, height, and other parameters.
Remember to set it to Always when you finish using this option.
Conditions can be accessed by clicking the icon next to the Condition Mask layer (and next to Degree); this gives even more access to various ways to apply your material layer.
Conditions refer to paint masking options that allow you to restrict painting to specific areas of a model based on surface curvature, lighting, or other criteria.
This function allows you to, for example, paint more in a cavity, more on peaks, or more on a specific color or even a mask.
It’s a helpful way to paint in detail, such as grime around nuts or rusty colors in rust spots.
To use any condition remember first to Edit > Calculate curvature and AO maps.
These conditions are
Always: Applies to every pixel of the layer.
More on Concave: This applies to areas that are more concave and lets you fill crevices. The condition allows acting stronger on concave areas. The cavity map will be generated as a separate layer automatically.
More on Convex: Applies to more convex areas, applying the material to more rounded external surfaces. The condition allows acting stronger on convex areas. The cavity/curvature map will be generated as a separate layer automatically.
Less on Concave: Similar to More on Concave, but applies in the opposite form by allowing a little less in concave areas and a little more in convex.
Less on Convex: Similar to More on Convex, but applies in the opposite form by allowing a little less on convex areas and a little more in concave.
More on Flat: Applies only to flatter surfaces.
More on Curve: This applies only to more curved surfaces.
More on Lit: The condition allows you to act stronger in lit areas. Uses an Ambient Occlusion map to determine placement: you need to calculate the ambient occlusion map to use this condition. Use Edit→Calculate Occlusion.
More on Shadow: The condition allows you to act stronger, darker shaded areas. You need to calculate the ambient occlusion map to use this condition. Use Edit→Calculate Occlusion.
More on Top: Applies only to the upper areas of the surface.
More on Bottom: Applies only to the bottom areas of the surface.
More on Sides: Applies only on the sides of the surface. The condition acts stronger on the sides of the model.
More on Bright: Acts stronger on bright pixels. The only color of the current layer is taken into account.
More on Midtone: Acts stronger on pixels with medium brightness. The only color of the current layer is taken into account.
More on Dark: Acts stronger on dark pixels. The only color of the current layer is taken into account.
More on Picked: Acts stronger on pixels with a color close to the currently picked color. The only color of the current layer is taken into account.
More on Bumped: Acts stronger on pixels that extrude outward. Only displacement of the current layer is taken into account.
More on Dent: Acts stronger on pixels that extrude inward. Only displacement of the current layer is taken into account.
More on Bumped & More on Dent:
These two condition options seem to only work on layers with displacement applied.
On separate layers, this option does not work.
On the upper right side you can adjust degree & contrast
Remember that Conditions only work on freeze for sculpt surface mode or Surface Paint on vertex on Paint Room.
But the standard sculpting brushes do not respect conditions, only work on Freeze mask to restrict where surface sculpting tools will be applied to the surface of the model.
If you like to edit the RGB Curvature map on Smart material Editor
1. First, you need to add Conditions to Degree value (more on convex like example) to see “vase” options.
2. Focus on a new edit icon -it looks like a vase-, this was added and did not exist before, and it is with the spin edges that the update function is configured. It is the additional cavity width: The 0 value means that the cavity is taken from the materials settings as-is.
Values less mean sharper cavity, more than 0.5 – widening of the cavity. Or course, you need an RGB cavity layer in the scene to vary the cavity width.
It works only on such conditions: more on concave, more on convex, less on concave, less on convex, more on flat, and more on curved (you can use any of these modes).
3. The new parameter is responsible for the radius cavity. It is also affected by degree and contrast adjustments.
– Overall Cavity Modulator
– Cavity area width
– Additional Cavity width
– Degree
– Contrast
Conditions Painting: Conditions refer to paint masking options that allow you to restrict painting to specific areas of a model based on surface curvature, lighting, or other criteria.
Conditions Painting quick start: This video demonstrates the usage of Conditions to apply paint according preset restrictions, such as Cavity/Recessed areas, Edges/Protrusions, Flat, Curved, Lit, Shadow, etc.
Cavity Masking and Painting: This video demonstrates Conditions-based Masking & Painting inside the Sculpt Workspace of 3DCoat, which allows the user to confine Sculpting and Texture Painting edits to specific areas of the model’s surface.
1 Yes  No
Brush Options panel
Strips Panel
