• Українська
  • Документація 3DCoat
    • Питання/Відповіді
    • Навчальні посібники
    • Питання/Відповіді
        • Autopo Baking guide
        • Autoretopology Guide
Entire Mesh
565 views 0
Relax: Relax the entire retopo mesh or subset. If you are in “Select” tool in vertex mode then only selected vertices will be affected.
Import: Import retopo mesh.
Export: Export poly mesh.
Subdivide: Subdivide poly mesh.
Smooth (CC): Subdivide and smooth the whole current group with the Catmull-Clark subdivision.
Smooth Selection CC: Subdivide and smooth selected faces using the Catmull-Clark algorithm.
Delete Mesh: Delete poly mesh.
Symmetry: Apply symmetry to the mesh
Unwrap: Fit all islands onto the UV map.
Automap: This is exactly same method of unwrapping as used in import dialog for automapping. It is planar mapping with test of clusters self-intersection. This method is most stable and eats any (even nonmanifold) geometry but creates too many islands.
Save contour: This command allows to save contour in real scale as EPS or DXF for further laser cutting. Length of lines corresponds to geometrical length. It is helpful if you want to cut shape using laser cutter and glue parts together.
StemCell model: Now 3DCoat 2025 added the StemCell command to ensure that your models meet all requirements without having to check them manually.
With one click, the Stem Cell Validator checks and corrects your work against TurboSquid guidelines.
The following functions have been added to help you make your 3D model compatible with the StemCell 3D modeling specification on Turbosquid.
These functions are implemented as a C++ script inside the 3DCoat program. When you click a certain button, the process of checking the 3D model in different 3DCoat rooms for compliance with the corresponding certificate is started. This process runs in a semi-automatic mode. When the script sees a discrepancy with the StemCell certificate, it stops, issues the appropriate messages, and offers you to take manual actions to correct the necessary errors. After you correct the errors at this stage, you need to restart the entire process from the very beginning. In this way, you go through all the stages of checking the 3D model and at the end you get a set of files that need to be uploaded to Turbosquid, so that your model receives the status StemCell Certified.
To start this process with your 3D model please import it below and then press Start button.
Tags:entire meshmodeling
Loft surface example by Fluffy
