On start-up “3DCoat for Linux” automatically enables tablets which it is able to recognize.
Otherwise the tablet should be enabled manually by defining the environment variable “COAT_PEN” equals the name of the input stylus device.
Wacom
For example:
export COAT_PEN=”Wacom Intuos3 4×6 Pen stylus”
Since “3DCoat 4.9.70 for Linux” it outputs into the Terminal the list of your input devices.
Please see the attached screenshot as an example.
You have to send a screenshot with the name of your input stylus device (similar screenshot as the attached) to me (support.linux@3dcoat.com).
Then your input device name will be added into “3DCoat” to automatically enable it in the future builds.
You have to add the tablet name a first time before it revealed more input device names.
One of the new ones revealed will be the correct one. As example “XP-Pen Pen Pen (0)”.
Sometimes adding the mouse device made the scroll wheel stop working inside 3DCoat – however leaving the mouse variable empty it work.
X-Pen
Start 3DCoat in terminal and see what Input devices it will give you. Than set environment variable according to that, before starting 3dcoat next time.
As example:
So next time before starting 3DCoat from terminal, you will setup env variable by executing
export COAT_PEN=”XP-Pen Pen (0)”
than start 3DCoat.
Українська
English
Español
Deutsch
Français
日本語
Русский
한국어
Polski
中文 (中国)
Português
Italiano
Suomi
Svenska
中文 (台灣)
Dansk
Slovenčina
Türkçe
Nederlands
Magyar
ไทย
हिन्दी
Ελληνικά
Tiếng Việt
Lietuviškai
Latviešu valoda
Eesti
Čeština
Română
Norsk Bokmål
