ไทย
English
Українська
Español
Deutsch
Français
日本語
Русский
한국어
Polski
中文 (中国)
Português
Italiano
Suomi
Svenska
中文 (台灣)
Dansk
Slovenčina
Türkçe
Nederlands
Magyar
हिन्दी
Ελληνικά
Tiếng Việt
Lietuviškai
Latviešu valoda
Eesti
Čeština
Română
Norsk Bokmål
เอกสาร 3DCoat
Chapters
Introduction to 3DCoat
Getting started
Interface
Brush Components
Workspaces Rooms
Scripting & Core API
คำถามและคำตอบ
licensing
บทแนะนำการฝึกอบรม
Pilgway
Products
3DCoat
3DCoatTextura
3DCoatPrint
PBRLibrary
Blog Posts
Store
ไทย
English
Українська
Español
Deutsch
Français
日本語
Русский
한국어
Polski
中文 (中国)
Português
Italiano
Suomi
Svenska
中文 (台灣)
Dansk
Slovenčina
Türkçe
Nederlands
Magyar
हिन्दी
Ελληνικά
Tiếng Việt
Lietuviškai
Latviešu valoda
Eesti
Čeština
Română
Norsk Bokmål
Creating 3D Character Using 3DCoat
Getting started
System requirements
Activating 3DCoat
Startup error
Startup error Mac
Upgrading permanent license
Linux Setup
Linux initial setup per-user installation
Linux initial setup for system
Tablet setup
To GTK3 from GTK2
Folders Structure
Custom documents folder
Different Forms of “Resolution”
Import and Export
Applinks in 3DCoat
Blender 4.1 applink
Blender with the Applink in Linux
Blender 4.2/3 applink
Max Applink
Houdini applink
Lightwave uplink
Navigation
Opening Dialog (Quick Start Menu)
Navigation Panel
Camera and Navigation
Customize Navigation as Blender
Viewport Navigation Gizmo
Left tool panel
Activity Bar
Navigation using 3DConnexion devices
How to compile Spacenavd on non Ubuntu distro
Stylus doesn’t work in sculpting
Hotkeys
Interface
File
Edit
Calculate Curvature
Calculate Occlusion
Light Baking Tool
Preferences
View
Symmetry
Textures
Calculate
Layers
Freeze
Hide
Bake
Curves
Curves editor
Fill with mesh layer
Splines model creation
Scale of imported curves
Windows
Tabbed and Popup Panels
Controls
Scripts
Addons
Capture
Help
Room Customization
Modify or Create new Room
Brush Components
Brushes general use
Create alpha brushes and decals
Making alpha from current sculpt
Create a Brush from a 3D Object
Create brushes based on Curves
Load photoshop .abr brushes
Strokes
Curves Popup Menu
Brush Options panel
Brush Top Bar
Conditions Limiter
Strips Panel
Stencils Panel
Smart Materials
Add new images or materials
Attach a Smart material to a layer
Import Quixel Material
Presets for Brush alphas
Workspaces Rooms
Paint
Texture Painting & Modes
Per Pixel Painting
Displacement Painting (Micro-Vertex)
Ptex Painting
Surface Painting (Vertex painting)
Importing Into the Painting Room
Initial CC subdivision
UV Set smoothing
Sharp (hard) edge
Lock Normals
Load new UV layout After Model Changes
DAZ Genesis models into 3DCoat
Paint Menus
Edit menu
Textures Menu
Texture Baking Tools
Hide
Bake Paint menu
The Color Picker
Top Bar for the Painting
The Layers Panel
The Blending Panel
Layer and Clipping Masks
Left Tool Panel
Opacity & Transparency
Tweak tools
Tweak Toolset
Exporting from the Tweak Room
Stencil & Material preview panel
Exporting from the Painting Room
UV
UV Top Bar
UV Left tool panel
UV Preview Panel
UV workflow example
Importing Into the UV Room
Exporting from the UV Room
Retopology
Importing into Retopo Room
Retopo Mesh Menu
Virtual Mirror Mode
Bake menu
Autopo Baking guide
Baking guide
Top Bar
Select geometry
Left tool panel
Overall Purpose & Function
Add Geometry in the retopology room
Strokes tool in Retopology
Tweak Tools
UV Tools
Commands for Retopology room
AUTORETOPO
Autoretopology Guide
Poly Groups
Sculpt
Sculpt Tree
Sculpt Layer
Brush engine
Sculpt Brush options
Right mouse button menu
Geometry menu
Shader
Voxel mode
Pure Voxel Sculpting
Density and Resolution
Clay Engine
Right-Click Menu
Voxel Tools
Surface tools on Voxels
Voxel Adjustment Tools
Volumetric Painting
Transform Tools
Voxel Objects Tools
Voxel Primitives & Import Tools
Surface mode
Surface tools
Surface custom tools
Surface adjust tools
Surface transform tools
Surface Painting
Surface Objects Tools
Sculpt Primitives & Import Tools
Multi Level Resolution
Multires tools
Multires adjust
Multires commands
Right-Click Menu
Sculpt curves
Spline Curves
Commands for Sculpt room
Vector Displacement
Live Booleans
Import to Sculpt Room
Exporting from the Sculpt Room
Render
Comparison of different roughness values
Render Panel Functions
Turntable
Fakebake the lighting -non PBR-
Factures
Workflow
Simplest
Modeling
Mesh Menu
Left tool panel
Add Geometry
Tweak
UV panel
Commands panel
Selected
Entire Mesh
Loft surface example by Fluffy
Blockout by Poeboi
Import Zbrush Polygroups for UV mapping
Kitbash
3DPrint
Photogrammetry
Reality Capture doesn’t show up ?
Nurbs
Nodes
Sculpt shader Nodes Library
Scripting
Core API
Python API
Free 3DCoatPrint
0
Written by
Carlos
June 19, 2023
Tags:
attach smart material
Yes
2 No
3DPrint
Nodes
Right-Click Menu
Baking guide
Autopo Baking guide
Send
0
Attention:
This is a beta version of AI chat. Some answers may be wrong. See full version of
AI chat
